TDINIT
Hello All
Figured id share...
I swapped an ALH code TDI from a 2004 beetle Into a MK1 Chassis (GTI)
Found the car local
Had the swap from a part out beetle
Had the 02A from a previous project
Figured id get it going and sorted NOW before the snow starts
1.9L ALH in mk1 rabbit
^^ The car I bought (He kept the stupid wheels!!!)
^ The transplant as removed from the beetle (2004)
^^ middle of the wiring process
^^ ALL stock stuff
Super short serp belt
Removes power steering + AC.
The Following is a parts list
ENGINE:
ALH engine management
121 Pin EDC15
^^ Rocket chip imo. egr. isv. delete .. Plus stg2+
DBW pedal welded to fire wall
12V "smart" glow plug relay system (Late)
China intercooler + piping
Dual speed fan setup (NEVER RUNS!!!)
Electric helper fuel pump + Pump~duse fuel cooler
innovate WI-FI hot spot generator and IPone as digital dash............
Mechanical:
CTN > 02A
^^ Has 02J tower + cables w/box + pin ends
Scirocco 16V axles
NLS internal water pump mount kit (Modified for ALH)
Manual Clutch Cable Conversion (Eurovan)
billet 02J FW. vr6 clutch disk + psi. plate (South Bend)
China intercooler + plumbing
02A starter
5Lug swapped for 11.3" front rotors (Redrilled drivers edition VR6!!)
rear disk swap to 10.1" vented
Manual inline proportioning valves
CHASSIS:
Manual steering rack
Stock Rabbit Sway bars F+R
BFI front frame bracket
FK silverline PLUS coil overs
Rebuilt EARLY rabbit Front strut mounts
85% of a poly Kit
Figured id share...
Found the car local
^^ ALL stock stuff
ENGINE:
121 Pin EDC15
Mechanical:
CTN > 02A
Scirocco 16V axles
02A starter
CHASSIS:
85% of a poly Kit
