A few weeks ago my Jetta warned LOW OIL PRESSURE, STOP ENGINE NOW and chimed at me.
I took the car to Auburn WA VW and we agreed to change the oil to a VW approved 505.01 motor oil.
That solved the problem, as the CEL has not sounded in over 3 weeks. And the car seems to handle better.
The manual for my 2006-2007 Wolfsburn Jetta specifies only 505.01 motor oil. I speculate that when I changed my oil about 3 months ago, that I used the discount motor oil I had become accustomed to using in my 2.2L Subaru engines. After several weeks, I speculate that the oil "thixotropy" broke down enough that it tripped the low pressure sensor in the engine. I have noted in the past that as oil breaks down, its viscosity and its "thixotropy" becomes reduced.
The engine was low by 1 quart of oil as well. But even after I topped it off, and rebooted the car computers by leaving the battery unplugged for a few hours, the code reappeared in the vehicle. Again I am speculating that the extra quart of oil did not reconstitute the "body" of the oil sufficiently to prevent the low pressure signal from being generated.
