p930man
Again, after clearing code, the light stays off until I shut her off and restart. then it doesn't turned off till cleared. I'm guessing the electronic portion of the actuator is not supplying the signal to the ECU???
On BRM Actuator is not available. Idparts has modified CR actuator , but not much feed back about it.- You could replace the actuator and see if it fixes the issue
