tons of "No Communication" errors - engine, trans, ABS, airbags, steering, cent conv.
Ghastly
mom's basement
2004 Jetta Sedan, 2009 Jetta Wagon
Hi, I hope some can help me figure out this problem. I have a 2009 JSW with 94680 km-58831 miles. About 6 months ago the MIL light came on. I finally got the HEX-NET tool from Ross and scanned the car. It had multiple "No Communication" errors. I cleared the faults, and they've all come back plus more.
The car has had very little work done to it. I had 2 temp sensors replaced by the dealer under warranty, and there's a slim chance my wife might messed up the fuse panel while trying to fix a burned out bulb :rolleyes: I don't know where to begin, has anyone seen this before?
Thursday,15,January,2015,19:07:40:32178
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: 3VWKL71KX9M313475 License Plate:
Mileage: 94680km-58831mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWKL71KX9M313475 Mileage: 94680km-58831miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: 12H01--- Serial number: VWX7Z0HD24C07P
Coding: 0050078
Shop #: WSC 91444 999 12574
VCID: BFCE0419EE008ED9D61-80EA
5 Faults Found:
049493 - No Communication with Instrument Cluster
U0155 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 5
Reset counter: 255
Mileage: 94450 km
Time Indication: 0
Date: 2000.00.00
Time: 14:14:35
Freeze Frame:
RPM: 1265 /min
Speed: 28.0 km/h
Temperature: 0.0°C
Voltage: 13.83 V
Bin. Bits: 00000000
Torque: 96.0 Nm
Temperature: 7.2°C
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 255
Mileage: 94450 km
Time Indication: 0
Date: 2000.00.00
Time: 14:14:35
Freeze Frame:
RPM: 1265 /min
Speed: 28.0 km/h
Temperature: 0.0°C
Voltage: 13.83 V
Bin. Bits: 00000000
Torque: 96.0 Nm
Temperature: 7.2°C
049478 - No Communication with Diagnostic Gateway
U0146 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 255
Mileage: 94450 km
Time Indication: 0
Date: 2000.00.00
Time: 14:14:35
Freeze Frame:
RPM: 1242 /min
Speed: 27.0 km/h
Temperature: 0.0°C
Voltage: 13.91 V
Bin. Bits: 00001000
Torque: 114.0 Nm
Temperature: 7.2°C
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 255
Mileage: 94450 km
Time Indication: 0
Date: 2000.00.00
Time: 14:14:35
Freeze Frame:
RPM: 1242 /min
Speed: 27.0 km/h
Temperature: 0.0°C
Voltage: 13.91 V
Bin. Bits: 00000000
Torque: 114.0 Nm
Temperature: 7.2°C
000310 - Oxygen (Lambda) Sensor B1 S2
P0136 - 000 - Malfunction in Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 94597 km
Time Indication: 0
Date: 2000.00.00
Time: 10:29:17
Freeze Frame:
RPM: 1380 /min
Speed: 57.0 km/h
Lambda: 0.0 %
Mass Air / Rev.: 525.0 mg/str
Voltage: 0.000 V
(no units): 0.01
Voltage: 0.225 V
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 051 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1814
Revision: 04843012 Serial number: 00000807010049
Coding: 0000020
Shop #: WSC 02069 000 90108
VCID: D0EC37A5439E01A13FB-8085
4 Faults Found:
18097 - Powertrain Data Bus
P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 255
Reset counter: 36
Mileage: 93315 km
Time Indication: 0
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 36
Mileage: 93315 km
Time Indication: 0
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 36
Mileage: 93315 km
Time Indication: 0
18288 - Powertrain Data Bus
P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 36
Mileage: 93321 km
Time Indication: 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B600D492300FD880F06EB921E0042B100
Shop #: WSC 00066 000 00000
VCID: F5A2A6315CBC0489CCD-80A0
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 7
Reset counter: 62
Mileage: 89659 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8208
Count: 50229
Count: 255
Count: 0
Count: 0
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 62
Mileage: 89668 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8233
Count: 50701
Count: 58073
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: F6A0A13D81BA0F91C57-80A3
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000001158478
Coding: 14890F2340041500070000001C000000000873075C000120000000000000
VCID: B2285D2D2D5253B129F-80E7
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 191208 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 2S AIRBAG VW8R 038 8600
Revision: 07038600 Serial number: 003E7M0874YD
Coding: 0012883
VCID: ED928E51F4ECCC4934D-80B8
Subsystem 1 - Serial number: 6332MSME4311520D0
Subsystem 2 - Serial number: 6342MSME4146380B9
Subsystem 3 - Serial number: 6351HSME1A4956068
Subsystem 4 - Serial number: 6361HSME1A4B6A40E
Subsystem 5 - Serial number: 63727SME19602C42$
Subsystem 6 - Serial number: 63827SME19603169$
1 Fault Found:
004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001032
VCID: 8248CDEDDD722331F9F-80D7
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 854 D HW: 1K0 920 854 D
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0002000 Serial number: VWX7Z0HD24C07P
Coding: 0007303
VCID: AC1443550F760541633-80F9
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 051108F1001163
Coding: ED807F06000202002002
VCID: B73E6C39C630B6991E1-80E2
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1222
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000655789118
Coding: 0001205
VCID: EFAE9459FEE03E59061-80BA
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: AA18454D05821B7191F-80FF
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 72
Mileage: 94450 km
Time Indication: 0
Date: 2000.00.00
Time: 14:14:35
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 20.0°C
RPM: 1421 /min
Speed: 55.0 km/h
Speed: 55.0 km/h
Count: 0
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 139007885283281B0904058FB0880F0488FCA0
VCID: F1AA9221E8D428A9105-80A4
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 254
Reset counter: 248
Mileage: 93220 km
Time Indication: 0
Date: 2000.00.00
Time: 15:22:42
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08102006184902
Coding: 0001204
VCID: F0AC9725E3DE21A11FB-80A5
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 019 0022
Revision: 00019000 Serial number: VWZ4Z7I6398791
Coding: 0040401
VCID: A00CA76573BED121CFB-80F5
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003686946
Coding: 0001168
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003659303
Coding: 0001168
VCID: F7BEAC3986B07699DE1-80A2
End-------------------------(Elapsed Time: 01:37)--------------------------
Stutgart
Pennsylvania
2009 Jetta
There is no magic bullet to fix them all by a single action. Here is what I would do:
1) Start by fixing the O2 sensor. That is the most important one since it is related to engine control, the engine is the most expensive item.
2) Once you have successfully cleared the p0136 O2 sensor problem, probably by installing a new O2 sensor at the correct location since there are 2 O2 sensors, then I would turn my attention to the steering. Perhaps a new J527 instrument cluster module with integrated G28 steering sensor will knock out a few of the fault codes, or maybe the connector is loose.
As far as causing all this be changing a light bulb, impossible.
Tdijarhead
Lawrenceville PA
2003 TDI Jetta Daughters Car, 2001 TDI Beetle, Wife’s car, 2005 Golf TDI Mine, all 5 spds
I think Stutgart is right about the O2 sensor. As far as the rest of them go, batteries that are on their way out sometimes will cause weird things to happen. Is your battery original and do you have the means to test it.
A5INKY
Vendor , w/Business number
Louisville, KY
2006 Jetta TDI, 2002 Eurovan Westphalia VR6
Those DTCs point to a CAN bus issue. Definitely make sure it has a good battery in the car as low voltage can cause all sorts of odd communications issues. I doubt that is what is going on with yours though. If it were I would have expected at least a few low voltage DTCs for the various controllers, you have none.
Here is a very good self-study guide to learn more about how the CAN bus system in your car works:
http://www.vaglinks.com/docs/vw/misc/vwusa.com_vw_mk5_jetta_electricalsystem_ssp_873403.pdf
...there's a slim chance my wife might messed up the fuse panel while trying to fix a burned out bulb :rolleyes:...
My money is on this^.
I bet there is either a missing fuse or burned fuse to a major CAN bus control module, such as for the CAN Gateway or J519 Central Electronics Control Unit. I'd get that owners manual out and make sure all the fuses in both fuse boxes are all good and where they are supposed to be. I've seen relay issues in a few cars too. I'd be verifying the ones powering the modules I mention are OK if the fuses are not the problem.
Ol'Rattler
PNA
2006 BRM Jetta
Ugh.:eek: The first thing you should do on a Dub before removing any fuses, is to take pictures inside of the two fuse boxes.
The owners manual does not come with fuse diagrams so if you pull a fuse and don't remember were it came from or someone not to savvy pulls fuses and doesn't get them back in the right place, you might really be screwed unless you can get a wiring diagram for your cars model and manufacturing date.
A VG place to start is to check for loose/corroded grounds. On my 2006, there is a large chassis ground underneath/hidden by the air cleaner box that has worked loose twice causing some mayhem.
tdiatlast
Fort Worth, Texas
I know we've got too many stickies, but maybe we need to have one that says,
"IF YOU HAVE SEVERAL SYSTEMS INDICATING MALFUNCTIONS AT THE SAME TIME, THE FIRST THING TO DO IS CHECK YOUR BATTERY AND ALL GROUNDS."
Ghastly
mom's basement
Thanks very much for all your advice.
It turns out a aging battery was a big part of my problem. With the car off battery voltage was good at 12.5v. With the car running, voltage was 14.5, so charging was good. But MIN voltage when starting was 9.65v, which is bad. So I got a battery from the dealer and swapped in in. After driving for 2 days, most of the codes are gone, but I still have the 000310 for the O2 sensor, the 01299 for the steering, and 00332 for the fuel cap.
I think I have to replace the O2 sensor, fix the fuel cap, but I don't know what to do about the comms error on the steering module. Any advice?
Coding: 0050078
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 95095 km
Time Indication: 0
Date: 2000.00.00
Time: 21:14:38
Freeze Frame:
RPM: 1840 /min
Speed: 93.0 km/h
Lambda: 0.0 %
Mass Air / Rev.: 435.0 mg/str
Voltage: 0.000 V
(no units): 0.01
Voltage: 0.225 V
Revision: 00H15000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 85
Mileage: 95107 km
Time Indication: 0
Date: 2000.00.00
Time: 21:26:02
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 25.0°C
RPM: 1638 /min
Speed: 69.0 km/h
Speed: 69.0 km/h
Count: 0
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 84
Reset counter: 34
Mileage: 93220 km
Time Indication: 0
Date: 2000.00.00
Time: 15:22:42
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 74
Mileage: 95073 km
Time Indication: 0
Date: 2000.00.00
Time: 11:55:35
