Old April 25th, 2010, 06:10   #16
eddie_1
eddie_1's Avatar
I had measured the MAP voltage from before with the 2.5bar stock map so I could compare with current 3 bar MAP.
Stock 2.5 bar MAP:
With Ignition on, Engine Off : 1.94V
With Ignition on, Engine Idle: 1.98V
3 bar MAP:
With Ignition on, Engine Off : 1.62V
With Ignition on, Engine Idle: 1.65V
It appears the ECU does not like the difference at engine turn on.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old April 25th, 2010, 08:49   #17
Curious Chris
Fuel Economy: 47/42/38
You have a PM. In my pile of spare parts I have a stock MAP. This will fix your problem.
Curious Chris is offline   Reply With Quote
Old April 25th, 2010, 09:11   #18
eddie_1
eddie_1's Avatar
I think you may have misunderstood the thread. I have both maps. I just installed the 3bar and there is an ECU issue with my current tune. I will put back the stock most likely. But thanks for the offer.
Old April 26th, 2010, 21:44   #19
Shawn_alh
TDI(s): ALH
right, i realized that after I posted. Your 18 PSI that you see on guage, vagcom or wherever will be under-reporting actual boost.
my gauge is not electric or digital
its analogue mechanical so how would it "under-report" is the boost the gauge showing me not "actual"
Shawn_alh is offline   Reply With Quote
Old April 27th, 2010, 04:56   #20
eddie_1
eddie_1's Avatar
You are right if you have direct air pressure measurement it will be good, most folks are going with electrical these days, so I was assuming your gauge was electrical. I meant anything based off the map voltage.
Old April 27th, 2010, 06:28   #21
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Who sells boost gauges based on the MAP sensor data?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old April 27th, 2010, 07:52   #22
eddie_1
eddie_1's Avatar
http://www.mcnallyelectronics.com/
Old April 27th, 2010, 07:54   #23
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Thanks!
Old April 27th, 2010, 09:46   #24
LiLredTDI
LiLredTDI's Avatar
Fuel Economy: ohh...I'd say bout 42mpg
i installed one last year at a gtg while waiting for rc to tune. pulled car out of bay after install and had limpmode as well. your car needs the ecu tuned for this part or it will continue to give you problems.
2004 Jetta PD-RC race, 17/22,stg.IIcoltcam PD150 Inj.,Rosten Rods, Ported head,PP DP, cat delete/2 1/2" piping/Magnaflo muffler, R32 airbox/snorkle,PD150 TIP, SB stg 3 ,NSboost/egt gauges, BBS RS II's, Koni FSD/Eibach Kit, M3 side skirts/ rearwindow spoiler,GLI F/R lips FK bumper scoops
LiLredTDI is offline   Reply With Quote
Page generated in 0.14012 seconds with 10 queries
[Output: 94.92 Kb. compressed to 81.40 Kb. by saving 13.52 Kb. (14.24%)]
