Cptnkush42zero
Seems to be every month or so she'll be driving fine then bam, you can hold it to the floor just to stay at same rpm and occasionally go up a hair then back down like fuel is being restricted. Everytime I dump a crap ton of diesel kleen in the tank or In filter it seems to clear up for a while. Really not sure if it's bad diesel, injector nozzles worn? Moisture in the tank from cold weather or? She does have 287k and a stage 1 Malone tune. it does cause the check engine light to come on, always between 2-3k rpm she will just sit and occasionally take off like it should.
