Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old October 6th, 2017, 06:29   #1
dieselsipper
dieselsipper's Avatar
Fuel Economy: Best 1315km using 54 litres, vented tank. Average 4.8L/100Km
Question 2012 Touareg brake pad wear sensor delete...Same as old VW's???
Just curious, is brake pad wear sensor delete the for a 2012 Touareg the same as old mk4 VWs, just cut and splice wires?
dieselsipper is offline   Reply With Quote
Old October 6th, 2017, 06:34   #2
oilhammer's Avatar
Fuel Economy: fantastic
Huh? You turn it off in the cluster coding, no need to cut and splice anything, or even get your hands dirty.
www.cardocautomotive.com
Old October 6th, 2017, 06:45   #3
dieselsipper
thanks
Old October 6th, 2017, 06:47   #4
oilhammer's Avatar
Sorry, I should have clarified... that is how you do it on the A4 cars, and B5s, and A5s, and C3s, etc. so I am *assuming* the T'reg is the same, it may not be. Can't say I have had anyone ask about turning it off on one.
Old October 6th, 2017, 06:54   #5
compu_85
Gadget Guy
compu_85's Avatar
Not sure on the '12, but on an '04 the cluster coding is identical to a Mk4 / B5.
The pads on the Touareg do start out fairly thin...
-J
Present:
2013 Fiat 500e. 22,000 miles.
2014 Cadillac ELR. 29,000 miles.
2004 Touareg V10 TDI. 165,000 miles.
99.5 Jetta "GLX" TDI. 310,000 miles. Half way there!!! Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is offline   Reply With Quote
Old October 6th, 2017, 06:55   #6
dieselsipper
I'm guessing same too, I'm not VCDS expert or actually even have one. I can get my hands on one easy enough, is it pretty straightforward?
EDIT: easily found with google search. Thanks for help guys!
Old October 12th, 2017, 12:52   #7
igiveup
It is pretty straight forward. Did it on a MK5 Jetta a while back. Don't remember exactly which module it is in. There is probably a "step by step" on TDI club somewhere. It was either just a check box, or a matter of changing a 1 to 0.
igiveup is offline   Reply With Quote
Old October 12th, 2017, 16:26   #8
Uberhare
Uberhare's Avatar
Fuel Economy: Depends on what I'm towing!
It is in the cluster coding. My wife's A3 won't allow it to be turned off. Wire broke on fairly new pads, so I joined the circuit.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old October 12th, 2017, 18:32   #9
QuickTD
In an a3 it is not a coding item. It is in adaptation block 37, last digit 1=pad wear active, 0=inactive.
Toureg could be similar, don't have personal experience.
QuickTD is offline   Reply With Quote
Brake pad wear sensor SOCALFIRE03 VW MKVI-A6 Jetta Sedan (~ 2011+) 4 October 22nd, 2014 04:59
Brake Pad Wear Sensor Herm TDI VW MKIV-A4 TDIs (VE and PD) 8 January 3rd, 2012 08:42
brake pad wear sensor benjaminearl Jetta/Bora/Vento TDI Picture Gallery 2 February 27th, 2009 22:51
brake pad wear sensor fruitcakesa TDI 101 2 August 17th, 2008 10:41
Front brake pad wear sensor jeffgraham TDI 101 7 May 2nd, 2005 19:07
Page generated in 0.14862 seconds with 13 queries
[Output: 96.07 Kb. compressed to 82.26 Kb. by saving 13.81 Kb. (14.37%)]
