I'm new here and I want to say hello to everyone.
At the beginning I apologise for my bad English, especially for small variety of words and spelling mistakes.
I would be great if you could correct those mistakes, for me it would be great lesson.
As far as I'm concerned your forum is said to be one of the best ones about TDIs - I hope that your profesionalism will help my in my issue.
I have got some problems with my VW Passat 3BG B5.5 2001 1.9TDI-PD 6-speed AVF... I mean AWX. This is my problem.
I have had serious breakdown (my turbo, pump-jets[correct?], and so have been seriously broken), so I decided that it would be cheaper to me to replace my engine with a new one. I found nice one and bought it. The seller said to me that this was AVF, but I did'n check it - then I didn't know how to do it. But after having it inserted to my car I found out that this is not an AVF - it is AWX... OFC clutch is from AWX, and other parts too.
Car seems to work fine, but I'm worried about its durability. I noticed that the fuel consumption is higher.
ECU is from the AVF engine...
Is it possible to remap my ECU to the AWX one? (from AVF)
Is it neccecsary? Can I get somewhere the standard MAP of AWX engine, or the ECU is different?
Clutch is from AWX, will the 6-speed gearbox work fine?
When plugged to the VAG-COM I always get some fault codes, but I'll write about them in another thread.
Thanks in advance.
Keisim
Thanks in advance.
Keisim
