torman
1996 Passat B4V Wagon TDI - $6499 SALE PENDING
sold!
sold!
My driver side window has slightly-off alignment too and was thinking to replace the whole regulator, can you suggest how the easy fix is being done?1996 Passat Wagon TDI (B4V) with approximately 139k miles on engine (installed new at 100k) and 239k on the body. 5 Speed Manual and gets low-to-mid 40's/~1100 miles per tank. Religiously maintained as documented by service records, including oil/oil filter, fuel filter, and belt changes. I am the third owner and have all the maintenance records since she was bought new. She's located in the Adirondacks. We moving up to a Eurovan camper, despite the enormous size of this wagon.
Pictures: http://burlington.craigslist.org/cto/2986759967.html
Overview
-Dark Green (good shape with no peeling; 2 small areas of bubbling)
-Tan cloth interior (good shape, except for small rip on driver's seat)
-Cruise control
-Central Locks
-Power Windows
-Two sets of tires (winter and summer) with 2-3 years of tread
-Roof rack
Major Maintenance History (since 100k)
3.18.11 - New 190F thermostat; new glow plugs & harness; new battery
2.10.11 - Fuel injector pump replaced
11.05.10 - New tie rods and alignment
3.18.10 - New coolant hoses/coolant flush
3.12.10 - New front window regs/ new ignition tumblar and module
4.24.06 - New A/C compressor and blower
12.2.05 - New rear window regulators
11.26.05 - Timing belt and rollers (170k)
7.29.05 - New clutch and service trans
5.5.05 - New rear brakes and rotors
10.18.04 - Motor mounts
8.25.05 - R&R intake manifold and exhaust downpipe
6.25.04 - New radiator fans
5.5.04 - New front brakes and rotors
1.12.04 - New radiator
Quirks
* Moonroof only works manually (needs new fuse, common issue)
* Driver's side window slightly off-alignment (common issue ... window reg was replaced in 2010; minor fix)
* Sometimes trip odometer and time resets (another common issue)
* Slight bubbling rust on driver's side windshield and fender (small and could be easily addressed ... surface rust).
Asking $6499 or best offer. PM me if you have any questions.
