Turbo_Whistle
I had this code pop up the other month. After some research I figured it was probably the ASV, but the car still ran fine so I didn't do anything for a few weeks. Last week on my way home from work I started to hear an engine noise almost like a miss or rough running. I stopped driving it and did full maintenance including oil change, oil filter, air filter, fuel filter and a brand new ASV. Cleared all the codes and the P0122 code comes right back.
I went back and checked fuses as well as wiring at the ASV and everything appears to be good.
Is there anything else that can throw this code? I thought the ASV would be an easy fix.
