migbro
Looking around under my Golf I noticed four open holes, two each side behind the rocker panels. Above these holes there’s a large enclosed space. Lots of potential for car-killing corrosion here if you’re in the rust belt.
I found three of the four missing plugs inside the body. The plugs had a thin external flange that had dried out and cracked off, with the plugs then escaping inside the body.
Here’s the part number for the replacement plugs: 1K0899185. This is an upgraded part that looks like it will be more durable than the original plug – 30 cents each from 1stvwparts.
