Hey guys, I don't know if this is the right place to ask since it's about a gasser, but it involves a TDI transmission. If it's the wrong place, please help me find where is the right place to ask. I already posted this over on VWVortex, but I get the impression of the people in the mk4 section there are not as helpful as TDIClub.
Anyways, here's the copy-pasta:
My mom's mk4 is a 2001 2.0 automatic (01M). It gets pathetic mpg for how slow and small it is. I blame this mostly on the transmission. Yes, I'm aware swapping to a 5 speed would increase the mpg significantly, but my mom is getting close to retirement age and I doubt she wants to row her own gears.
The idea has been hanging around my head lately of swapping an 01M that has the tdi gear ratios into her mk4.
Information from http://zelek.com/diagram_charts/diagramlist.htm.
Tranny Code________1st______2nd______3rd______4th______Final Drive__Engine
ECN,ELT,EBP,FDB____2.714____1.441____1.000____0.742_______3.700_____TDI
EFB,ELZ,EPH,FDG____2.714____1.441____1.000____0.742_______3.700_____2.0L
DYG,ECV,ELY,EPG____2.714____1.551____1.000____0.679_______4.875_____2.0L
ECM,ENZ,EPJ,FCZ____2.714____1.441____1.000____0.742_______4.267_____VR6
I would be using a used TDI 01M if I could find one in decent condition. This car's not worth enough to spend a ton of money on this swap; the cheaper the better. Obviously I would have to get the TCM that goes with the TDI tranny to make sure it shifts right. If I also had to swap axles, that would be fine.
My question: What reasons do I have not to do this?
Assume: I can get the parts cheap enough, I do the swap myself, swapping in a stick shift is not an option, the reduction in acceleration is a non-issue (how much slower would it be to a stock TDI auto anyways?).
Her daily commute consists of 20+ miles each way on rural, flat, straight, 55mph highway. Also, she's kind of a slow driver so the lack of in-gear acceleration is not a deal killer. Every so often when I find myself not able to drive my own car for whatever reason (read: broken), I borrow this Jetta to drive to school (junior in college) and she uses their Buick for the week.
Thank you!
Thank you!
