Spine
Hi guys,
I am about to take my 2003 TDI Jetta Wagon in for it's first oil change and I have a couple of questions before hand if you don't mind. I have decided that after the 16,000km oil change that I will use Mobil Delvac synthetic and do the oil changes myself but the first two times I wouldn't mind them checking the car for abnormal break-in signs etc and I would like to see how they perform the oil changes.
1. Has anyone here been to Crosby VW/Audi in Kitchener, Ontario for Service? If so, would you recommend me going there again, do you know if they will do the EGR mod for me? (I don't have a vag-com yet)
2. My stock headlights seem aimed too low (i always feel i am over driving the lamps at even 90km/hr) and I just noticed in the fog the other night that my highbeams seem to cross and form an X. Is this normal? I don't want to sound like an idiot when i go to the stealership and get them to re-align the headlights (I will be getting e-codes in october when i go to germany but until then I want the best out of my stock lamps)
3. Can anyone from ontario tell me where to go to get the fram quick drain plug mechanism that replaces the oil plug to allow quick oil draining via a valve (and also hopefully reducing the chance of the stealership x-threading the oil plug) If you have a part number or a good description of one that would work good for VW a4 tdi engines that would be great, as well as opinions on these devices (ie is the valve more likely to fail than the oil plug seal, is it worth it? etc.)
Thanks in advance to all those who reply to my message.
Mike
Mike
