codylent
I really hope that someone can help me with the problem I'm having. Recently my oil cooler went bad and I got coolant into my transmission fluid and transmission fluid in my coolant. I had them both flushed at the Volkswagen dealer. Ever since the problem happened, it has been shuddering really really bad. By shuddering I mean, it sound like it can't decide to shift up or down and the whole car vibrates. It only happens when the car winds out and is at low rpm. I was told by a friend to try Lubegard ATF protectant. I contacted them and found out it is safe for Volkswagens. I put that in and the problem got about 60% better. I contacted them again and they said try another bottle. Now the problem is about 85% of the way gone. I am scared to put more in. Should I try using more? Is there something else I can do?
