KO
- Joined
- Aug 23, 1999
- Location
- Tulsa, OK USA 99.5 A4 Jetta TDI
I also, took mine out. I hope we are doing the right thing. The only concern I really had was if the filter would get wet. I drove for about 30 minutes in a storm and I didn't even have water in the airbox much less a wet filter. One other thought. Does the engine, or is the engine management system designed to work best with the reduced flow from the screen? Could the increased airflow increase emissions or something? Could the increased airflow increase internal pressure in the engine?
I guess time will tell.
KO
KO
