Start from the beginning. I recently did some major work to my 2004 TDI. New Colt Cam, new injectors, new intercooler (non OEM replacement, is just a bit deeper then the stock one, old one was worn through....), new lifters, TB, WP, and clutch.
After I finished it ran good for a bit. But shortly after it was throwing some codes. I replaced the Glow Plug harness which seems to have resolved a couple of them. However I am not sure where to start with the P1592 and P0101 as the MAP is a bit more expensive. This problem seemed to come on slowly and it seems to be in limp mode as it loses power and the engine sounds a bit different, kinda like the turbo is not spooling as much.
My first thought is that when I swapped out the intercooler it had a new sensor on it so I just used that instead of the one that was one the original intercooler. Because it is a non OEM intercooler I am guessing it is a non OEM sensor. The intercooler was purchased from ID Parts and I trust they sell quality parts. Here is the one I got: http://www.idparts.com/intercooler-bew-jetta-golf-p-3691.html
My other issue is that when I try to test the MAF sensor with my VAG-Com on address 3 I don't get the MAF actual vs specified, just actual. Did something change? Where can I find specified.
So where would you recommend I start and how can I get MAF actual vs specified? I was not able to find it anywhere in the VAG-Com.
