Whisper
Cross-posting this from a reply in one of the many update threads so it's easier to find for anyone who may have the same issue as they get their recall done. If you can concretely say that this is or is not related to the update, please do so-- I'm still new here.
Quick driving history:
Gave the car to the dealership at 121,588 miles for the software update. Took them about an hour and a half.
Drove home (15mi)
Car sat for about 20 minutes
Drove to get coffee (1.3 mi)
Car sat for about an hour
Drove home (1.3 mi)
Car sat for about two hours
Drove to UCI (25 mi)
Car sat for about three hours
Went to leave UCI
-surface streets, fine
-got on the freeway, got up to about 65MPH and went .5 - 1 mile and PING
So we're looking at, really, two warm starts and two cold starts (assuming I'm using that phrase correctly-- I'm new to all of this), with a mix of surface streets and highway (non-traffic hours) driving. I'm pegging the estimated traveled mileage between update and CEL at 40 - 50 miles.
I kept on driving after the CEL light went on, radio off, listening to my car and feeling for any deviance in the usual vibrations-- the general rumble of my car (post-service, pre-CEL) was -much- more bass..ier... than usual for the first 20 or so miles after the service, but that was gone by the next day.
Put 5 gallons in my car before parking at my house.
CEL was still on the following morning. Car still sounded and felt normal. Went to get coffee (1.3 miles), was in the shop for about five minutes. Came out, started car, drove about, oh, 20 feet.
And the CEL went off. I have no idea how normal that is. I've never had that happen to me, on any car of any make I've owned.
Drove down to the dealership. The light stayed off. Noticed that, after about 20 miles of highway driving, sitting at the signal at the exit ramp, my car was pulsing. I've noticed that maybe twice ever, and I've had this car for five years.
So the brake pedal is vibrating under my foot with this steady, almost regular heart-rate pulse. But the car isn't pulling forward and the RPMs were steady. I could hear my engine doing it, once I turned off the radio.
Drive to dealership, park... car is still pulsing. Turn off car. Regen was cycling. Don't know if that's what I was feeling.
Go talk to the service adviser. Explain that I had the update done the previous day, what had happened, and that I wanted a scan to see what had set the light off. Told him about the pulsing. He refused to believe that my car wasn't actually pulling forward and that were the RPMs unchanging.
Tells me no problem, will totally scan... for $140. If it wasn't the result of the update, that was the cost. If it WAS the result of the update, they'll apply it to the repair. THE REPAIR FOR WHATEVER MIGHT HAVE HAPPENED DUE TO THE UPDATE.
I think my reply involved some shocked profanity.
So I called my mechanic (5 miles away), and he said he'd scan it and give me the print-out (he knows I love my print-outs) for $47. Sure.
Additional info: An exhaust sensor went bad two weeks ago or so. Details on that below (just in case there's an impact that needs to be taken into account), then details on the fault that caused my CEL to come on after that.
What flagged two weeks ago:
001146 - Exhaust Pressure Sensor 2
P047A - 000 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 44
Reset Counter: 255
Mileage: 173669 km
Tim Indication: 0
It also caused:
16815 - Warm Up Catalyst; Bank 2
P0431 - 001 - Efficiency Below Threshold - Intermittent - MIL ON
And:
000262 - Manifold / Barometric Pressure Sensor )G71) / (F96)
P0106 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 4
Fault Frequency: 2
Reset Counter: 40
Mileage: 198574 km
Time Indication: 0
Freeze Frame:
RPM: 800 /min
Mass Air / Rev.: 152.6 mg/str
Temperature: 43.5 C
Idle
Voltage: 14.18 V
Speed: 0.0 km/h
So those showed on today's print-out. The new ones?
001025 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 4
Reset Counter: 255
Mileage: 194268km (120712 mi)
Time Indication: 0
Date: 2027.14.03
Time: 23:33:08
Freeze Frame:
RPM: 1495 /min
Speed: 47.0 km/h
Voltage: 13.68 V
Load: 85.9%
Load: 100.00%
Mass Air / Rev. : 295.0 mg/str
Mass Air / Rev. : 440.0 mg/str
001025 - EGR System
P0401 - 001 - Insufficient Flow - Intermittent
Freeze Frame
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 2
Reset Counter: 255
Mileage: 195733 (121623 mi) <---PING
Time Indication: 0
Date: 2027.14.19
Time: 08:14:20
Freeze Frame:
RPM: 2323 /min <---DOUBLE CONFIRM
Speed: 118.0 km/h
Voltage: 13.68 V
Load: 96.1 %
Load: 100.0%
Mass Air / Rev.: 475.0 mg/str
Mass Air / Rev.: 470.0 mg/str
I don't know enough (yet) about this particular sensor and what all of the numbers above mean, but I did have my ash load checked yesterday at the dealership and it's only 120.0mL, so if my DPF is going bad at that load a low and causing some sort of clog, I'm going to be pretty upset.
Not sure if it's related to the update, since it happened 900 miles earlier. What I don't understand is why the same error happened with a higher frequency but my CEL did not come on.
If it could be related to the update, as it looks like it has to do with emissions (pardon my ignore), feel free to chime in. I'm going to make a new thread for this in 2010 Jetta TDI category so it doesn't get lost in the chaos of having so many threads on this software update. Maybe I can get help sorting it out there and soothe your concern.
Can you let me know the name of your guy over there? I actually live in North OC and, while I like my (non-dealership) mechanic a lot, I want another opinion on pretty much everything now.Oh, please do, for I've had nothing happen with my car since I drove it off the lot. Although I have a super tech, who is the only person I allow to touch the car at the new Norm Reeves dealership in orange county, this ECU modification/update does have me concerned.
Drove home (15mi)
Drove home (1.3 mi)
Went to leave UCI
Freeze Frame:
Fault Priority: 2
Fault Frequency: 44
Reset Counter: 255
Mileage: 173669 km
Tim Indication: 0
It also caused:
And:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset Counter: 40
Mileage: 198574 km
Time Indication: 0
Freeze Frame:
RPM: 800 /min
Temperature: 43.5 C
Idle
Voltage: 14.18 V
Speed: 0.0 km/h
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset Counter: 255
Time Indication: 0
Date: 2027.14.03
Time: 23:33:08
Freeze Frame:
RPM: 1495 /min
Speed: 47.0 km/h
Voltage: 13.68 V
Load: 85.9%
Load: 100.00%
001025 - EGR System
Freeze Frame
Fault Priority: 2
Fault Frequency: 2
Reset Counter: 255
Time Indication: 0
Date: 2027.14.19
Time: 08:14:20
Freeze Frame:
Speed: 118.0 km/h
Voltage: 13.68 V
Load: 96.1 %
Load: 100.0%
