volmaniac
We have ODB-II emissions check and I am trying to make sure all my readiness codes are good before I take it to the emissions facility. MOGolf reported that VCDS can check the readiness codes using Group 17 in the Measuring Blocks. Can someone help interpret these results:
the bin bits and should be boxes have me confused... if I have 00000000 (which I believe means the readiness checks were passed in a gasser) in the first bin bit box, is the "should be x000xxxx" box showing 00010111 mean that the readiness checks are failed or incomplete? Thanks in advance.
