Old July 25th, 2017, 13:30   #451
Apothecia
Fuel Economy: 38/42 (26/30 twoing the A-frame)
These are all great suggestions. Thank you!
Apothecia is offline   Reply With Quote
Old August 12th, 2017, 17:02   #452
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
I am wondering if anyone has used moog springs in the last year?
all the previous catalog discussion about rock auto seems to not exist.
Im weary that the moogs will give any lift as no store (online) can confirm that these are for a wagon specifically. Will be checking locally soon.
moreover, I found two 2002 wagons at the local pick n pull one had 1.8t the other 2.0 and one had two silver and three green springs while the other had two brown and one green. I can't find any info about these.
dhangejr is offline   Reply With Quote
Old August 12th, 2017, 17:03   #453
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
I asked about the three green two silver before and one person said "there is no reason to think they would not provide a lift" but there is no other conformation.
Id rather just buy new from IPD that guarantee 1.5' lift for $99 vs the 50$ its gonna cost at pick and pull on a Saturday with the blond working. lol
Old August 12th, 2017, 21:27   #454
JohnTso
Fuel Economy: 51/47/42
I put MOOG VR6 springs - front & rear - on my Mk4 Jetta and I'm very happy with them. I got them from RA lat last year. My car definitely sits higher, but the OE springs were shot.
I posted pictures under the title of Desert Jetta reveal.
JohnTso is offline   Reply With Quote
Old August 12th, 2017, 22:39   #455
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Yes I have seen that. I think I might try and new moog springs in the 1 inch spacer
Old November 17th, 2017, 18:34   #456
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Well, still researching , I'm a week away from going up , waiting on the front TC's in the mail. (Less than 100$ at FCP BTW)
Anyway, my research has led me to some interesting data
How to get spring rate WITH OUT a machine!
Here is the formula and an explanation
http://www.bluecoilspring.com/rate.htm
I believe it's accurate because two white and one green is 154 lbs (fronts) according to common data form vw gurus. And my calculations with fast measurements got me about 141.3lbs. Very close enough to say there's a small margin of error.
Maybe someone needs this? I wish I had those different color rear wagon springs I found and was wondering f about. I imagine th
Old December 9th, 2017, 18:59   #457
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
Ok, so I went up finally. Im up about 30" in the rear and 29.5 up front.
My rear end is making a metal on metal rattle. I don't think its shots toping out they are extended. Im damn frustrated. I don't wield nor do I have any friends who will help me.
A few weeks ago I found someone who said they were using a bilistean rear shock that was extended but was not designed for MK4's. Now I can't find it. I think (based on my internet search history) it might be BILSTEIN 33-230351
can anyone confirm this or has anyone read this?
http://pics.tdiclub.com/showphoto.ph...e=lift&cat=500
Old December 12th, 2017, 07:28   #458
jmodge
Mine rattled when I put Moog wagon springs in also. Only the right side and I found after twisting it to match where the left was seated it quit.
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old December 12th, 2017, 09:23   #459
dhangejr
dhangejr's Avatar
TDI(s): mk4 Jetta
I took my shackles off and the problem is gone. Now the shocks are maxed out.
The tears a bit hop happy. I'm going to get wagon struts prolly koni reds . First I'll call IPD and ask for measurements of the various wagon struts they have. I want good travel on dirt FS and BLM roads
Difference btw VR6 springs and jetta wagon springs Quanger Ontario 4 April 8th, 2014 08:35
Wtb: Mk4 Vr6 Wagon Springs EZC6083 Private TDI Items for Sale/Wanted 0 May 29th, 2010 10:56
WTB: VR6 Front Springs, Jetta Wagon Rear Springs OlyTDI Private TDI Items for Sale/Wanted 15 May 8th, 2010 09:35
WTB wagon or VR6 front springs cameron69 Private TDI Items for Sale/Wanted 9 August 21st, 2009 17:53
VR6 Springs in a TDI Jetta Wagon? adam_alexander Upgrades (non TDI Engine related) 1 July 29th, 2006 12:53
Page generated in 0.17400 seconds with 13 queries
[Output: 92.08 Kb. compressed to 79.15 Kb. by saving 12.93 Kb. (14.05%)]
