Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old December 28th, 2017, 11:05   #1
MTB_TDI
Default Post your VCDS auto trans controller info.
Now that some of you are getting the emissions fix done and are unhappy with the new transmission tuning, we need to see if we can get a transmission tune to get back what everyone lost.
To do that, we need to get a database of what everyone has for the VAG Number and the Component.
Please list if yours is post fix or not and vehicle info.
Here is my info:
2015 Touareg TDI
My VAG Number is 0C8 927 755
Component: AL1000 AISIN 100 2817
NO FIX.
MTB_TDI is offline   Reply With Quote
Old December 28th, 2017, 13:54   #2
Savageman69
Savageman69's Avatar
id love to know which controls the manual shift response rate....drove a 2017 gas treg the other day and the up and down manual mode is 100x more responsive then the setup in my 2012....i was going to put paddle shifter wheel in but its so laggy i figured it was worthless but if i could get it to shift like the 2017 id do it.
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap - EGR Cooler Delete
Savageman69 is offline   Reply With Quote
Old December 31st, 2017, 12:27   #3
Blownvette
I donít know about the newer cars but the 2004 and 2008 v10tdiís I have shift much faster with the paddle shifters than the console shifter. I do know that there is a coding change when I added the paddle shifters so that could be part of the difference or the micro switches in the paddle shifters may be quicker?
Blownvette is offline   Reply With Quote
Old December 31st, 2017, 18:08   #4
Savageman69
no the 2017 wasnt an r line...this was console vs console
Old February 17th, 2018, 04:03   #5
MTB_TDI
My calculated risk paid off! I bought a new TCM and put it into my Touareg. Then I took it in for the fix and the TCM made the Touareg stay in a lower gear running around town. It would stay in 3rd as I was running through the neighborhood when it used to run in 4th or maybe 5th. I then put my old TCM back in and it changed my shift patterns back to normal.
The new fixed TCM seems to require more throttle when using partial throttle. I am not a fan. So if you want to have your old shift patterns post-fix, get a new TCM and put that in your Touareg when you get it fixed.
I would be willing to “lend” mine out if yours is compatible.
Old February 19th, 2018, 11:58   #6
Radman
You could also seek a local tuner and have it re-programmed. But your idea is definitely a good one. I dont care for the shift patterns in mine since the fix, but will be getting tuned come spring anyways.
2014 Audi A6 TDI
2014 Touareg TDI
Radman is offline   Reply With Quote
Old February 19th, 2018, 12:20   #7
compu_85
Gadget Guy
compu_85's Avatar
If you find a tuner that does Aisin transmissions share with the rest of the class. I went looking last year and didn't come up with anything affordable.
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
compu_85 is online now   Reply With Quote
Old February 19th, 2018, 15:19   #8
Savageman69
yah there are no tuners that do aisin trans
Old February 20th, 2018, 08:13   #9
Radman
I work for Unitronic, we are working on it. May be a few months down the road as Diesels are not priority for us.
2014 Audi A6 TDI
2014 Touareg TDI
Old February 20th, 2018, 15:53   #10
Savageman69
be nice to see but plenty have tried to break the code on aisin transmissions and most give up. Im interested to see how this pans out
Old April 2nd, 2018, 20:51   #11
yrktreg
Do you guys have any ECU Tunes..?
I thought that I heard that this JR tuning company has a TCU tune out..
Their website doesn't even show T3 capability, so someone should let me know that they may be missing customers
Not sure if it's for the T1's, 2's, or 3's
I can flash your TCM back to the original factory pre-flash fix software.
Here's what currently available for your Treg:
FL_0C8927755__
version 2882
version 3074
So I would say that going back to the 2882 version would restore anything that the 3074 put on there...
yrktreg is offline   Reply With Quote
Old April 3rd, 2018, 04:53   #12
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Here ya go:
http://forums.tdiclub.com/showthread.php?t=487077
Also, Savageman69, that gasoline fueled 2017 model you liked most likely had a ZF transmission installed, not the slushy Aisin box. German transmissions work better in German cars it would seem, because I have experienced the same thing.
That said, the engine also makes a difference.
oilhammer
www.cardocautomotive.com
Old April 6th, 2018, 12:56   #13
Radman
FL_0C8927755__
version 2882
version 3074
Not yet for the ECU. Just lack of time basically especially this time of year we are busy and TDI's are a small portion of the market.
We do have a tune for my 2012 Passat although we have not officially released it on our website. Need to re-tune after the fix and re do the Dyno runs to see if any changes.
2014 Audi A6 TDI
2014 Touareg TDI
VCDS with real controller will not connect to Airbag KillyMcGee TDI 101 7 June 24th, 2015 06:54
Help Accessing 02-Auto Trans Adaptation VCDS and DSG VWJayhawk VW Passat Family (NMS and B7) TDIs (2012+) 10 December 31st, 2013 22:23
VCDS 10.6.3 only fined one controller UHF OBD Scanners 6 March 15th, 2011 21:17
05' Tiptronic Auto Trans. Vs Auto Trans. in a 2002 - Explain the Diffrence + - ? convict TDI 101 5 November 14th, 2010 17:04
VCDS: Steering wheel controller question JSWTDI09 OBD Scanners 5 February 13th, 2010 16:39
Page generated in 0.19564 seconds with 11 queries
[Output: 118.85 Kb. compressed to 100.02 Kb. by saving 18.83 Kb. (15.84%)]
