CR140 Performance Parts Help...
storx
Earth!!
2009 Jetta CR140, 2010 Corvette Z06
I have asked in my build thread before and never got an answer on if there is a readibly available kit of ARP head bolts for my engine... and never got an answer. I also was planning on doing a cam upgrade but the person who was all about doing it hasnt responded to me in a long time.. i hope i can get my money from him on the deposit for the cam..
Parts i am looking for help on:
ARP Head Bolts
CR140 upgraded camshaft
CR140 upgraded valve springs
storx
Earth!!
before you go and say that i should just ask arp, i did already my Question Number: 58031 ended up with an answer of "we are unfamiliar with the CBEA engine".
v8 coupe
bloomington, mn
09 rabbit 2.5L Gas
No studs exist yet, cams do, but they aren't cheap, I have yet to get a spring package done yet that clears the rocker arms.
mctdi
se WI
2010 Jetta
On the APR studs, I had called years ago for my 2004 Golf. At the time they said they did not have kit for the PD yet. But if I would send them an OEM head bolt, they would create a kit.
TDIsyncro
Saskatoon, SK
Audi/TDI x 2
there are currently no ARP's that are a direct fit. I used ARPs but they needed modifying, You are best to buy a set from Matt Whitbread as he does have a set made for the CR.
