sandcroy said:
Hello Dan group 11 readings are 918mb at 9.9% with test off and 1030mb at 90.3%and the EGR test 390mg at 100.6% duty cycle and with test on 210MG at 80.5 %... the car runs great now after 1 turn adjustment on set screw on turbo, amazzing how 1 turn can make so much difference and now the EGR test runs without killing engine. Lets me know what you think of these new numbers after the adjustment
The turbo numbers look fine.
It looks to me as if you have something wrong with air flow. It should be about 450 mg/str with the EGR off (100% DC). Either your MAF is reading low, or your EGR valve is not fully closing (which is not uncommon on BRM engines.) You are losing about 13% of your low rpm fueling (power), because you are 13% low on air flow.
If you have not posted this, would it be ok if I did?
Sharing information is important.
