TDikook
yup, I need a new one too. (my third) but the crack is there till I get extra money, after all my mods. I can live with it for now.
Gear oil has nothing to do with your clutch slipping. Its always more likely that your clutch will slip in winter. Your lack of slipping now is likely due to your warm Georgia weather. I'd be more concerend where that missing gear oil went.andreigbs said:Replaced my 5 spd. tranny fluid which had 73K miles. Less than 1 quart came out! Filled it up with G52 (1.6 L) and guess what, NO SLIP IN ANY GEAR! Used to be that I couldn't use all the torque from RC1+ because it would slip in 3rd, 4th, and especially in 5th until past 2,5K rmps. Not so anymore! It pulls like a train with no slippage whatsoever. Thought I'd be needing a clutch right after I got RC-ed, but for $21 (new fluid) all is well in my TDI world.
I asked dealer if they ever replaced rear axle bushings before, and he told me that they just replace the whole axle beam instead of bushings. After I replaced myself those bushing I understood why they just replace the whole assembley instead of just bushings. Replacing rear axle beam would probably about same or less cost then paying labor cost to have bushing replaced. They are not too hard to remove them, but pressing them in is pain in rear.NarfBLAST said:Dropped her off for new rear axel bushings (one of them had fallen out!) at 295,000km... they are also replacing siezed right rear brake caliper (left was replaced last year). Quoted $800 for the job. Wife said that if the new Jetta Sportwagon was available in TDI we coulda traded her in instead of fixing it... but alas. We wait.
New diesels, where are you?
Sootman I am about to install a R32-air box,Lift pump with AL-MOD, VNT17/22 RC6, OMI,and PP 2.5 DP, do I have to be careful with the tranny? how does you car pull with RC6 and 17/22? I can not wait to try the TDi out with these mods.Sootman said:Great time for a 6-speed!! or a Peloquin with a 5-speed. I'm a little worried these days about the tranny too. Sorry to hear about yours. We're pretty closely matched car wise.
Do you remember my post on this back in 2006? If you did you'd remember the forest.TDikook said:well brian, at least there weren't plants growing it it.
Nice car!!IndigoBlueWagon said:Loaded up the Golf and headed for Detroit. Didn't get out of the house until after 6:00 but got to Syracuse at 11:30. Here's a picture of when we're ready to go:
The ride is pretty firm with the coilovers and 550F/350R springs. And the 80 durometer mounts make it loud: earplugs are a big help. But it seems to be doing pretty well on what I think is a crappy tank of fuel, probably low 40s at 75 MPH with about 80 miles at 90 (on Route 495 in MA, of course).
Not based on my experience. I've beat the crap out of mine for 7-years now and the only issue so far has been the need to replace 5th gear. It was a good opportunity anyway as I've got a 5th gear ratio that works better on the secondary roads around here. IndigoBlueWagon (TDIParts) came up with this idea and it's great.Tisey06 said:Sootman I am about to install a R32-air box,Lift pump with AL-MOD, VNT17/22 RC6, OMI,and PP 2.5 DP, do I have to be careful with the tranny? how does you car pull with RC6 and 17/22? I can not wait to try the TDi out with these mods.
