Actually it is not too bad. The NMS' dash is nicely constructed, very good materials. Worst part is there is no easy way to do it without taking the front seats out, which isn't hard either, but just adds more time to the job.
Still finicky to get in there on the on motor, though. It is behind a bracket on the driver's side of the case, in the middle, and I had to get a 6mm zero offset ratchet wrench (cute little thing!) to make it faster to get one of the screws.... otherwise, you'd have to do even more work.
Dash work on newish cars, so long as the owner/operator is a total pig, is pretty nice. You don't get dirty. And with all the Ford and Toyota evap cores failing left and right lately, we have plenty of opportunity. The Ford Transits are the best, you have to remove the right DOOR to get the dash out! LMAO!!!!
