Fix_Until_Broke
In your bottom picture at about 10:00 location is a high cycle fatigue area (actually ~7:00 to ~11:30) and it looks like there was a crack started there maybe with a rusty edge.Frankendiesel said:Here's some picture of the carnage:
Thanks for your input everyone. I'm working with some mechanical engineers to figure out the best way to get these half shafts setup properly. I read some forums on racing pages about welding half shafts...they say don't do it. CFM, does TIG welding induce a lower temperature on the welded material? If so, yours might be in a little better shape. It took about 500 miles for mine to snap. Right now, we're leaning towards repairing (with a longer bushing to compensate for the broken piece!) and then annealing them both to neutralize the localized hardening effect. At least, that's our theory for now.
Also, thanks for all the input on the surging. I'll try to get the brake and clutch switches wired in properly. Right now, I have the clutch switched 'bypassed.' That is, a jumper in the connector so I can start it! IOW, the ECU thinks the clutch is depressed all the time. If that and the new AHU pedal don't make the surging go away, I'll look at the injection adjustment as recommended.
Thanks again!
The rest of it looks like low cycle fatigue
I think the trouble with welding it is getting it/keeping it straight to prevent bending which will cause the fatigue on the outer side of the bend.
I think the thing to do would be to make a sleeve or bushing or collar to hold both halves of the shaft co-axial, then weld each half to the sleeve. Clearances should be tight (couple thousandths or less if possible - a light press fit is fine acutally.
I don't think you want to anneal the whole shaft as the CV cups need to stay hardened. You might be able to locally stress relieve the welded areas while keeping the cups cool, but if it's TIG welded, you might not have as much trouble due to better heat control of the weld.
Might be worth a try compared to having custom axles made?
