nokivasara
How does the ECU decide if a bulb is broken or not before it lights up the bulb out indicator?
I have a false sporadic LH main bulb warning and that happens to be where I take the trigger for my light bar relay, so I suspect that has something to do with it.
The light bar is wired with a SPST relay powered from bat+ and triggered from the main beam wire, nothing strange there at all.
It seems to work fine during summer but now that it's colder it lights the bulb in the dash every now and then at startup, never after that. The bulb out light goes out if I turn on the mains (and light bar) for a few seconds...
So, does the ECU look at the resistance at the bulbs or is it more complicated than that?
Would a relay with a flyback diode help?
Or a relay with a specific resistance?
