2004LB7
See if that fixes the photos
Ok, what is that?
Kerma says they can fix them after a pump failure. Check with Charlie.its alive !!!
well almost. it is down on power and smokes
i am thinking the injectors are trashed
here are the ballance rates
#1 = +0.65 to +0.75
#2 = +0.65 to +0.75
#3 = +0.00 to +0.22
#4 = -0.99 to -1.25
do any of you think there is any chance of an adventurous one like me of taking the injectors apart and cleaning them?
That Mechanic is not right in the head..Same happened to me. 80-ish on timing belt, and 17 hours away from home. Decided I would do the belt when I got back. Unfortunately, the belt decided to go out when I was out of state. Had to take to VW dealer. I did check belt first by taking off top timing cover and cranking, and cam turned as it should. No fuel flow, and started with ether, so I decided on changing the lift pump in hotel parking lot. Ended up being teeth on crank chewed off. I thought it, and see it a lot, but the mechanic at dealer said BEWs are not interference engines. New belt, wp, tensioner and I drove it home.
