Hasenwerk
Vendor , w/Business number
- Joined
- Nov 28, 2003
- Location
- Quesnel, BC
- TDI
- 1982 Cabriolet (BEW|VNT17|Stage4), 1989 VW TriStar Syncro soon-to-be CR TDI (CBEA), 2001 Ford Ranger Edge 4x4 (ALH|VNT17|R520|Stage4)
The brake / clutch input is a safety thing as well as a cruise control thing.evguy1 said:It's nice to see you offer a drop in harness for the Ranger.
The harness is the hard/scary part for a lot of people and the reason they don't do a swap.
The Ranger harness you built for our Ranger worked great and cut our conversion time by many hrs.
I'm curious what the brake input does?
I did not connect it on our Ranger and the truck runs perfectly.
I just assumed it was for cruise control which our Ranger does not have.
When connected, if you press the brake it will automatically reduce fueling - hence the "no fun when left foot braking" - this can be disabled in software so that you can have cruise control and left foot braking while applying the fuel (when the CCS is off). The clutch is also used so that when you shift it reduces engine power / shudder. Neither is 100% critical to have but I recommend using them. Also, in some ECUs, if the measuring blocks for F / F36 / F47 are not all "0" then the ECU will reduce power. If F and F47 do not switch at the same time you will get an "implausible" DTC and the ECU will go into safe mode - hence the use of the relay for this.
In the photo, next to the grey OBD and Accelerator pedal cables you will see a heavy black wire with a ring terminal on it - this attaches to the battery.Rockwell said:Where does the main power tap into for the glow plug relay? Is it part of that harness?
