Old March 12th, 2008, 19:22   #1
nicknack2
nicknack2's Avatar
Exclamation Rough Running
Guy, my 06 Jetta's engine is vibrating alot, is not missing... mileage is normal, just moving alot at idle, once is in gear and thru the gears there is no problem just rough.
"NAV"
nicknack2 is offline   Reply With Quote
Old March 12th, 2008, 20:51   #2
Russnut
Russnut's Avatar
Fuel Economy: City/Hwy (heavy foot) 45mpg avg.
motormounts? mines got a slight wobble, and it's the rubber in the transmount.
2003 Jetta GLS 260k Miles 1849 hybrid, PP764s, OMI, Boostvalve, 3Bar map, autometer phantom, straight pipe, WRD dogbone, Kerma Tune, G60 Clutch, 2.5" Drop, Winter Grill Covers, Frost Heater, EGR delete, Yakima Snowboard Rack, Hella 500s and lightbar
Russnut is offline   Reply With Quote
Old March 12th, 2008, 22:05   #3
dr.diesle
Fuel Economy: 900km to tank but alota black smoke
mine did that, lent it to the wife and well she still has it ///is it using oil and or smoking a bit?
dr.diesle is offline   Reply With Quote
Old March 12th, 2008, 22:16   #4
nicknack2
nicknack2's Avatar
serviced as per vw manual, im thinking maybe fuel filter
"NAV"
Old March 12th, 2008, 22:21   #5
dr.diesle
well if its serviced as per manual then why fuel filter not done yet these pds are hard on fuel filters but thats always what peoples think first I should invest in a filter company ... these engines have an injector problem so if under warranty I would have it checked unless there is a mil light on at least have it checked but dont get me wrong a bad wheel bearing will make a vib not enough info to go further
Old March 13th, 2008, 06:27   #6
nicknack2
nicknack2's Avatar
Exclamation Not a wheel bearing....
the fuel filter has not been done yet because it got just under 15,000 on that filter, not wheel bearing because vibration happens only at idle, it runs smooth under acceleration and the fuel mileage it is still around the 40's, so I know it is hard to get a web dignosis of the problem, but Im just looking for the "usual" issues on the mighty PD!
"NAV"
Old March 14th, 2008, 06:17   #7
nicknack2
nicknack2's Avatar
guys I started to hear a noise towards the front right side of the engine along with the vibration, still runs good just the vibration and now the thun thun thun sound towards the front right side of the engine it has now about 56,000 so It will be going in the stealership on monday....
"NAV"
Old March 14th, 2008, 08:35   #8
bmwM5power
bmwM5power's Avatar
maybe it is DMF givin up?
bmwM5power is offline   Reply With Quote
Old March 14th, 2008, 20:34   #9
dr.diesle
hey nicknac I would like to hear how you say that it may be a wheel bearing try and turn wheel when driving ever so slightly to see if noise changes if so its a wheel bearing ....dealer will hose you on that as per anything
Old March 15th, 2008, 07:39   #10
nicknack2
nicknack2's Avatar
Exclamation
around 40,000 miles I took it in because "noise" (DMF) as usual the dealer could not duplicate the noise, this time is more than the DMF Im thinking lifters or even a rod, when I start the engine there is no noise when warm the thunk, thunk starts, no issues with wheel bearings, it makes the noise at idle...not rolling
"NAV"
Old March 17th, 2008, 09:49   #11
nicknack2
nicknack2's Avatar
Exclamation
Good morning, well I'm here at the VW dealer, the Jetta has 56500 miles on it I talked to one of the sevice reps and he seemed like he could not duplicate the noise then he sat in the car and noticed it... I hope they will fix it, I'm betting on internal engine stuff, the fuel mileage has been great, I have 480 miles on this tank and still above 1/4 tank so it is hard to say, I also changed the fuel filter to see if the problem went away W/O luck fuel econmy has not changed and other than the vibration at idle the Jetta does not miss.
I'll keep posted
"NAV"
Old March 17th, 2008, 12:52   #12
nicknack2
nicknack2's Avatar
they said that it is the trasmission mount, and they are trying to find out if that is covered under the drivetrain warranty...any body knows???
"NAV"
Page generated in 0.19699 seconds with 10 queries
[Output: 103.48 Kb. compressed to 86.07 Kb. by saving 17.41 Kb. (16.83%)]
