hybridfreak
Hello!
My original 10mm IP (ASV engine) died this summer and I replaced it with a 11mm IP from an automatic. A previous owner had the car chipped at ABT (from 110HP to 132HP) but I decided to take it a tiny bit further and started remapping it to 1,25bar @ 2500rpm and a nice torque curve that shouldn't kill the clutch too soon. All that has worked out pretty well, there's just one thing I can't get rid of - boost spikes.
Whenever you increase the throttle pedal position, boost pressure will go to about +40-50% of what is requested and then settles to whatever level it should be at. When slowly applying throttle it doesn't happen...
Now since the change in IP results in a ~20% increase in IQ there's more exhaust gas flow spooling the turbo faster than the ECU anticipates. So I decreased IQ in two maps by 20% (torque limiter, driver's wish) and adjusted the smoke limiter to lambda > 1.3 (taking the extra IQ into account). Still spikes.
Adjusted the N75 map to open the vanes earlier and further. Still spikes.
Now what? I don't know what else to do and I really dont want to kill that tiny GT1749V.
Should I decrease the values in the pump voltage map's IQ-axis according to the added 20% of fuel?
Cheers,
hybridfreak
Cheers,
hybridfreak
