JST
Ah ok, missed that part. We will see what happens.Hay JST I explained that the 4-1 header is for higher RPM range
Yeah, nothing wrong with the looks!They look great!
I am convinced the tubular will be better for flow/ highend power.@JST - The tubular manifold is on my car from the beginning... One log manifold can spool like my tubular, but in the high RPM range, the log manifol would be the worst scenario.. IMO
I assume you'll test the both manifolds on a 2056vk, correct?
Thanks for that comment Ryan, that makes sense.The difference low end from the extra volume would be so minimal IMO that the turbo vanes closing a touch more would overcome any 'lag' created by the manifold.
good merge is where the power is on these!
Actually thats not really the case I think, at the very ends of the vane position turbine efficiency is tapering off steep. Manifold volume acts like a spring, not a perfect spring unfortuately so its more like a spring/damper in reality, its like you're running in loose sand on a beach.The difference low end from the extra volume would be so minimal IMO that the turbo vanes closing a touch more would overcome any 'lag' created by the manifold.
Nope, the guy that makes the manifold is very busy atm, so it still needs to be finished.Hay JST have you got any photos and/or dinos yet?
Good point, my bet is the volume of a OEM manifold is less than half of a tubular. I'll measure it today.So this thread has got me curious as to just how much volume difference there is between my 4into1 tubing manifold and a typical cast log manifold. So I just clamped a plate over the turbo flange on mine and filled it with water from a graduated flask. It took exactly 1060 cc of water to fill it flush to the top of the cylinder head flange. Anyone know the volume of their cast log manifold for comparison? Unfortunately I don't have a cast manifold here to measure.
Delayed SOI and lower railpressure helps till a certain level. Edc17 has a function to delay soi based on rpm and boost governor error
OEM design looks indeed not that bad. Areas of improvement are the merge section and outlet. The outlet is enlarged but still a few mm's smaller than the GTB turbine intake. Making it larger would make the wall thickness too thin for my liking.That manifold looks like it should flow pretty decent. Seems you were pretty much spot on with your guess on the volume difference.
I'll see If I can measure that for the log manifold.I'm using that manifold for high horsepower so volume isn't important.Keeping the heat in is the most important factor when comparing to a tubular manifold that "flowed well" in my opinion.Lost heat is just as bad or worse than having unnecessary volume I would think.Andy do you happen to have one of those not bolted to an engine, that you could easily measure the volume on?
Thanks.There pridy. Nice block hugers. When are you testing it and what are you going to teat other then hp, ft-tq, boost pressure?
