Fellows, I removed EGR and it was plugged. I cleaned the EGR valve and exhaust pipe tube from EGR to exhaust manifold. EGR is free now and checked with vacuum pump and stays open when vacuum applied. Put everything together, clear the code withy my Vag-Com. After 100 kms of driving the chaeck engine light came on with the same code. Any other suggestions or fix to this annoying problem???
Either your EGR valve is not opening (likely) or your MAF is reading too high (unlikely). You said it opened when you applied vacuum, so next thing to check is if the vacuum line that goes to it has vacuum at idle it should be sucking pretty good.Here are the readings with Vag-com
Idle 913/min, MAF Specified 355.0mg/str, MAF Actual 465 - 475mg/str, EGR 84.5 %.
Thanks everyone for helping me with this problem.
it wont let me view the thread, it says im not of privilege aha but my cars reading egr code and im in the process of checking if there is any vaccum, or if it is the harness so if anyone has any pointers or help its muchly appreciatedI came up with this "maf twist" fix:
EGR del and CEL, new quick fix - TDIClub Forums
But before you wade thru that thread, can you tell us what your MAF Specified and MAF actual are reading at idle using VAG-COM? Also it would be worth wile to test your MAF using vag-com following the procedure in the TDI FAQ if possible.
Yep, emissions device defeating topics are banned from this site, so, I have posted a couple of videos on YouTube with explainations on how to do the MAF twist and how the EGR system works... will add these links to my signature too... These videos are for interest purposes only and not to be discussed here (or this thread would be deleted too):it wont let me view the thread, it says im not of privilege aha but my cars reading egr code and im in the process of checking if there is any vaccum, or if it is the harness so if anyone has any pointers or help its muchly appreciated
