PoloPD
Hi, i have a VW Polo PD100 that was sat for quite a while and i never topped up the tank. I changed the oil and filters and had it running on my drive for a total of about 2 hours, no problem. I then drove the car to work, again no problem. But when i started it for the trip home it started misfiring and then cut out and i haven’t been able to get it going since.
I scanned the car for dtc’s with VCDS and none appeared for the engine control module, so i assume the issue must be with the fuel? Especially as it was sat in the tank for around a year. I’m thinking maybe the lift pump sucked up some dirt at the bottom of the tank and pumped it into the fuel system.
I put a pipe onto the lift pump and pumped all the old fuel out and filled the tank with new fuel, i also emptied the fuel filter and filled with new diesel but still no joy. I then brought some redex fuel cleaner and filled the fuel filter with it, i cranked the car for a good while hoping the redex would clear the lines but again still no luck.
I have just removed the tandem pump and injectors and blew compressed air through the feed and return channels, cylinder 1 and 2 were initially blocked but managed to clear them. I have just rebuilt the car but again no joy!!
I am now thinking to remove the tandem pump again and blow compressed air through the channels while turning the engine over by hand to open the injectors.
I am selling the car so i am reluctant to purchase any new parts for it. Can anyone help out?
