charley654
I am on my second tank of fuel, and also vent through my first regen with this car.
Regen was as usual, raised idle speed, cooling fans blasting, noticeable noisier exhaust tone at the tail pipe as well as hotter exhaust coming out of the tail pipe, MPG drops on MDF.
Two things that are new to me on this new engine behavior:
Also want to verify if others are experiencing the same thing.
1) idle speed seems to fluctuate with no good reason btw about 850 RPM and about 1000 RPM. (not during regen.)
I am thinking this may have something to do with keeping emission parts hotter for EPA reasons.
Sometimes in park at normal engine operating temps
RPM may be 1000 other times 850- minutes apart. AC on or off does not matter. In gear (D) waiting at the stop light , same thing it is either 850 or about 1000 RPM. (again not regen). it did this from day 1 with 15 miles on the car.
2) relates to regen: with the new urea injection, is the additional fuel dumped during regen to heat up DPF, is fuel directly injected after the turbo and front of the DPF?
3) head lamp output/ halogen: is it reduced power to 12V (bulb life extender) like it is on the Passats? or is it getting full alternator output/battery voltage?
Did not see anything in VCDS.
