Enabled
Car Background Info:
So 2 weeks ago my 3rd gear got progressively worse to go into gear. It would take some playing around to get it to go in, with slight grinding. It got so bad, that I started avoiding 3rd to prevent damage. I went and ordered new syncros (3rd and 4th: PN 02A311269E to fit the original 02A syncro hub).
I was planning to take the transmission off AGAIN, after the recent clutch/flywheel update. What a pain.
Anyways, a few days later 4th gear completely stopped engaging, so I figured it may be worse than I thought, and waited to the syncros to arrive. Put the car on the lift...
I took out the transmission, and opened it up.
The syncros are not the issue, as they are perfect, and within good measurements (1.3 mm space). Sent those back for refund.
To my surprise, the shift segments for 3rd and 4th (pegs on shift fork that move hub up or down) were ground down to almost non existent. I will take a picture of it soon. It's like they were milled down completely by the hub. (segments #9 in below pic)
(#2 in this picture)
However, the hub, including the channel, gears, and syncros were largely undamaged.
Only my reverse gear was found to have been chipped and damaged, so I ordered new shift segments with clips, as well as a reverse gear.
Here are pictures of those as well for curious people.
Now, I will have my transmission back together with new parts this weekend without problems...
The big question that remains:
Why and how did this happen?
I had the proper amount of fluid in the transmission from the gear swap.
I have properly adjusted the shifter at the time of the clutch/flywheel swap, just ~10,000 miles ago.
Manufacturing flaw? Bad heat treat?
Has anyone else seen this before?
These strange problems are making me view VW more and more negatively each day. My 3 BMW's haven't given me this kind of strange problems (including a few others on this VW) combined. Rant over.
I'm very mechanically inclined, and have access to pretty much any tool, and specialized equipment, including a whole machine shop to use.
I would like to understand why.
I lived 6 years in Europe for college, and seeing VW's popularity (and reliability) there, made me consider one. I'm not at the point of regretting, but it's pushing my patience.
- 2003 Jetta TDI Manual with 02J EGR transmission,
- new upgraded G60 single mass flywheel and upgraded clutch (10,000 miles ago).
- Running a .681 5th gear (with Pennzoil synchromesh oil done at swap),
- and PP520 nozzles.
- Some very mild 3rd gear grind noticed on downshifts (4th to 3rd) since I bought the car.
