Old December 13th, 2011, 18:39   #1
Racing4funn
Default I cant pass emission without a air bag module
If I have a check engine code for any reason then I fail. This is a ex-flood car and the water got up high enough to take the airbag module out that is located on top of the center hump below the dash and radio.
Ive been driving this car for months and its been a great car but the check engine light is on and airbag light too. I removed the module and called VW dealer. With the number shown on the module they told me there is two version of this box with the same exact id number. There are many others but the numbers are different. If anyone can get me one of these then I guess I got a 50/50 chance of it working. VW also said it would have to be programed by them. IS this true? Maybe (long shot) that both versions of the module COULD be programed.
What does anyone know about this?
Thanks!
Racing4funn is offline   Reply With Quote
Old December 14th, 2011, 04:07   #2
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
I would take a shot and try buying one from a salvage yard. Do you have access to vag-com. There really is no substitute for getting the exact codes. It will reduce the scope of troubleshooting.
The airbag and check engine light are likely unrelated. MIL is often glowplug related. I guess TN is more strict that TX. I had a MIL last year (GP related and now resolved) and the inspector said, "You are lucky this is a diesel. Any gas car would fail of the MIL was on."
There are some trusted mechanics in TN. You should use the VAG locator thread at the top of the 101 forum to find someone who can get you the correct codes.
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old December 14th, 2011, 05:48   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You really should not get a used SRS controller, for safety reasons. I'd order a NEW one, from your local dealer, based off of your VIN.
In 2001, the Golfs sold here could have come from Germany or Brazil, 2 or 4 door, with or without side curtain airbags. Your VIN is the only for sure way to get the correct control module, and even then it may still need to be coded for your car.
That said, I do not believe a non-communication issue with the SRS module should make the engine controller send an MIL request to the cluster, so you probably have something else wrong.
oilhammer
www.cardocautomotive.com
Old December 14th, 2011, 09:09   #4
Racing4funn
I have a vag-com. There is a code for the airbags causing a Check Engine light. Its been many many months since I saw the code and I dont remember how it was worded.
A new control module is discounted at just over $400. Thats not going to happen since I have $2k in the whole car. Im going to have to find a used one. Cant afford that much for a stupid module. Anyone know of a good place to find one?
Old December 14th, 2011, 09:12   #5
tdinewbb
TDI(s): 2003 Jetta
I am surprised that is required. I have had a airbag light since i bought the car, no problem passing inspection in PA....
tdinewbb is offline   Reply With Quote
Old December 14th, 2011, 21:36   #6
Racing4funn
They told me that if any light was on then the automobile was NOT operating as intended from the manufacture. It blows my mind too. Maybe they will frown upon having different speakers or seats in the car.. These guys suck. Im going to try another testing facility next week.. The check engine light code has something to do with the module being bad and they for sure will not pass me with that light on.
I still need to get this fixed as cheap as possible.. If the system is happy with a salvage yard module and it runs a test on the system periodically, then why buy new. Its not worth an extra $300+ for new. The dealer is going to program the module anyways if me just plugging it up dosent make the computer happy.
Old December 15th, 2011, 04:57   #7
oilhammer
oilhammer's Avatar
I agree about a used one working just as well, as if it runs its self check (which it does every time you turn the key on) then it should work the SRS system just fine. However, many auto recyclers simply won't sell used airbag components because of the liability. However, I doubt anyone at a 'self serve' type yard would even know what an SRS module is, if you yanked one out yourself and took it to the front counter.
You still may need to recode it, though.
oilhammer
Old December 15th, 2011, 07:12   #8
Kevin_McC
Fuel Economy: 49
I have a used one from a 2002 Jetta for sale at $100 shipped. I'll check the part number when I get home today
K. McClafferty
Pinckney, Michigan
2003 Jetta GLS TDI
Kevin_McC is offline   Reply With Quote
Old December 15th, 2011, 18:46   #9
Racing4funn
If it matches whats in the picture, I will take it. The dealer tells me there are two different ones with the exact same part number. guess that gives me a 50/50 chance. I will install it and see if all lights and codes go out and if not then take it to the dealer and see if they can code it.
Old December 15th, 2011, 19:24   #10
nadroba
nadroba's Avatar
Fuel Economy: 40 mpg
As far as I know airbags don't trigger the check engine light. They trigger the airbag light
'04 Jetta TDI
'05 Jetta TDI
nadroba is offline   Reply With Quote
Old December 15th, 2011, 22:06   #11
Racing4funn
I got both. I will rescan the engine like and report its wording and code.
Now that I think of it, maybe the engine light was for the deleted EGR.. Either way I need to and want to get the air bag system working.
Old December 16th, 2011, 14:20   #12
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
That WILL do it. Get the codes, I'm sure the MIL is not for the airbag system, that's what the airbag light is for.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is offline   Reply With Quote
Old December 16th, 2011, 19:04   #13
Vince Waldon
Vince Waldon's Avatar
K, that's a horse of of different color.
In anticipation of the next question, getting an ECU tune is the only reliable way to permanently deal with a CEL caused by a EGR delete.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old December 16th, 2011, 23:02   #14
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Genetic OBD ( the one they use in emission machine) won't pick up air bag code( data bus missing message for Air bag controller) in engine ECU.
Your problem is EGR delete.
If in your state they do emission test then you want pass emission if you have EGR delete. EGR monitor needs to be ready and it will not if you delete EGR,even with tune ECU
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old December 17th, 2011, 08:47   #15
Racing4funn
OH are you sure about that? I was counting on an ecu tune to remove the light and code and passing. You are saying that their system checks for EGR readiness?
I have a 03 mustang cobra (nearly a racecar) that dosent have any of the emissions stuff but it has a gutted cat for visual and flashed ECU to turn off all the lights. They hook up to it and everything looks good on their end so i pass.. Ive moved forward enough with this idea already that Im going to get the tune and see what happens anyways. I think they scan for codes only here. How else would I be passing?
Removing pass side air bag cover nate379 TDI 101 2 July 12th, 2010 00:07
Air Bag Module part # bilzer TDI 101 16 June 7th, 2008 04:41
Air Bag Module Failure bilzer VW MKIV-A4 TDIs (VE and PD) 2 October 5th, 2007 21:30
Air Bag module code 65535 bilzer TDI 101 0 August 29th, 2007 16:09
Disable pass. side air bag? silverback VW MKIV-A4 TDIs (VE and PD) 5 January 1st, 2003 18:04
Page generated in 0.19790 seconds with 11 queries
[Output: 130.30 Kb. compressed to 108.83 Kb. by saving 21.47 Kb. (16.48%)]
