Ok so I have an 04 Passat BHW. I did the BS delete and timing belt since the previous owner didn't know when it was done last. Made it 4 miles and the tensioner stud snapped and took out the valves. I got a used head in good shape and dug in. Got the head on an all buttoned up and it wouldn't start. So I put my old tandem pump on since I knew that worked as well as my old injectors. Still won't fire. I have primed the fuel system and made sure there is no air in it. As well as adjusted the injector rockers. Anyone have any thoughts?
