tongsli
Great! Thanks. Very good. I may test my 2000 TDI as well. I could also make an ISO to Quadlock harness.
thanks!
thanks!
Yes, I know that you were referring to the RNS2 can 1.6 that's what I installed in my MKIV 2004. And, I do know the Navi for the Golf V is can 2.0 but I cannot fit that unit into my dash because it has no locking tabs.wait a minute, i'm referring to the pre-restyling version of RNS2 installed on touareg / multivan. the one with squared corners.
Absolutely NOT MFD2 installed on golf V and above (round corners).
Pay attention cause the post-restyling seems exactly the same but it's not.
the pre restyling works at 1.6 can bus speed (so compatible with the golf 4 can bus cluster).
the post restyling works at 2.0 can bus speed, so it will not work.
for your other issues i don't know too much, since i've a 2005 leon (same of golf4) that i think has all the needed wiring for the can bus 1.6.
Maybe your golf 4 year 2000 couldn't have all the other necessary connections (gala, k wires, etc) to get the rns2 working properly, even if it's the pre-restiling version..
sorry but i'm not an expert in pre can-bus cars..
ok very well, so let me know if everything work fine!!Yes, I know that you were referring to the RNS2 can 1.6 that's what I installed in my MKIV 2004. And, I do know the Navi for the Golf V is can 2.0 but I cannot fit that unit into my dash because it has no locking tabs.
I am trying to see, with the adapter above, if I can retrofit the same RNS2 can 1.6 into MY 2000 MKIV TDI.
Since I have an RNS2, I can test it very easily I sent the ebay seller a question asking about K-wire connectivity with their can emulator.
if you mean the round corner golf V one, i think absolutely yes!!M206, just want to ask again is the RNS2-Golf version can 2.0?
ok, thanks. The canshack adapter is not cheap. almost $400if you mean the round corner golf V one, i think absolutely yes!!
be careful, i think the canshack adapter works only with rns-510/mfd3, and NOT with mfd2, it's not a universal can adapter from 1.6 to 2.0 i think..ok, thanks. The canshack adapter is not cheap. almost $400
yes sorry. i'm all over the place My Dream/Ultimate plans:be careful, i think the canshack adapter works only with rns-510/mfd3, and NOT with mfd2, it's not a universal can adapter from 1.6 to 2.0 i think..
but i could be wrong, just try and ask directly to stefan..
400$?? it's really expensive, here in europe we can buy it at 229€, it should be 295$, not 400..
