kmsbryans2018
Hi there, im new to the forum and fairly new to VW. My wife drives a 2015 VW Jetta with the TDi. The other day is was checking her engine oil level and noticed a components that had a lot of white crust encasing it. At first glance I thought holy craps that's a lot of battery corrosion... But then I realized it wasn't even close to the battery. When I got next to the crusty material I could tell it was from a Blue DEF leak and that what I was seeing was where it had crystallized. I'm not certain what to call the component that it appears to be coming from therefore I have no idea where to begin researching what needs to be done in order to fix the leak and repair the problem.
Side note:
On the instrument cluster, the light indicating to add DEF to the system was coming on along with the wrench light. Both were orange which according to the owners manual meant that something was malfunctioning with the DEF system. The check engine light was also on. Now the add DEF light and wrench light have turned off but the check engine light is still on. My assumption is that the engine light is related to the other 2 lights. I will have someone run the codes. But I need to identify this component so that I'll be able to figure out what to do next.
I'm a service manager for a Kubota tractor dealership and have been in the auto parts industry for many years but I'm just not sure what to call this component. Hopefully I can get some help from somebody here, on how to upload a photo to this thread...
Side note:
