How hard to turn injection pump?
muzy
Southern Alberta
02 jetta TDI
Like it reads?
Get you up to speed. changing out head gasket and new timing belt kit.
Since I'm changing leaky HG i did not bother to pin or lock anything during disassembly. Just have the Injection pump left to pin. Am trying to turn clockwise, but its a tough turn (well trying to turn) all lines are still caped off with rubber caps.
How much force is to much? Do not what to damage anything.
:confused:
Vince Waldon
Edmonton AB Canada
Quite a bit... big springs on the cam plate. As you turn it there will be 4 distinct spots where resistance gets the largest... that's the cam plate in action, once for each cylinder in a 4-cylinder engine. :)
