Old December 1st, 2019, 21:09   #1
Andyinchville1
Default ///// Aero hubcaps /////
Hi
Looking to get some extra fuel economy from my Jetta by improving aerodynamics.
When I was running steel wheels I simply drilled and bolted aerodynamic covers to the factory hubcaps and it worked fine. However, i switched my wheels to Avis aluminum rims to save weight and now I can no longer run hubcaps.
My dilemma is how to attach the aerodynamic covers to my wheels ( the aerodynamic covers I was referring to are the pizza pans available from Walmart .... ).
I've been a little reluctant to drill into the spokes to mount them so I've been leaning towards trying to utilize magnets to glue to the rim ( high-strength rare earth magnets)
It would be neat if I could do it using magnets because then there would be absolutely no indication of How It's mounted when viewed from the outside.... but the difficulty doing that is to precisely place and glue the magnets...
What are your thoughts on mounting this?
Thanks in advance for any and all help.
Andrew
2003 Jetta tdi wagon , 5 sp, 316k miles, 11 mm pump, DLC 520, Malone stage 1, P205 70 R 15 Ecopias on Avus rims, hammer mod
Andyinchville1 is offline   Reply With Quote
Old December 3rd, 2019, 07:55   #2
Pharcyde145
TDI(s): 2011 JSW 6MT
Man, I like this idea. It almost reminds of of the old "turbo-fan" wheels for the 80's. I think some wheel manufacturers like Rotiform offer an attachment, they call it an Aerodisc. (here's an example for a 19" wheel https://www.urotuning.com/products/r...yABEgIqcfD_BwE
At $125/ea I'd just buy a true set of turbo fan wheels, but to answer your question more precisely, it looks like they are attach via the cap for the wheel bolt. That's ideally where I'd look to attach also since it offers the most opportunity to "bolt on" and prevent detachment. Rare earth magnets are powerful, but so is the kinetic energy at work on the moving wheel.
Good luck!
Pharcyde145 is online now   Reply With Quote
Old December 3rd, 2019, 09:03   #3
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Get in touch with Aaron (Growler on the Forums) He had aero hubcaps on Schnurren a while back. Picture is HERE.
-George Bernard Shaw
Old December 3rd, 2019, 10:34   #4
thundershorts
remember moon hubcaps? mabe still available
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old December 3rd, 2019, 11:47   #5
scrambld
Run a bead of construction adhesive (adhesives are available to bond to metals) around the outer portion of the rim and affix the aero disk. It'll have a clean look.....and make breakdown a bit more work
Not so clean would be self tapping screws into the outer rim.....much the same using screws to prevent tire slippage (on wheel) on cars set-up for drag racing....you could even go into the tires bead a bit to prevent tire/wheel slip.....oh wait, you don't drag start as you're doing the hypermile thing...LOL
scrambld is offline   Reply With Quote
Old December 4th, 2019, 06:29   #6
Growler
Got Soot Vendor
Growler's Avatar
I still have 3 of those, sized for stock 15" alloys. somehow my son lost one on the road.. he probably didn't get it fully seated after having to put air in a tire.
they were purchased on Amazon for about $75 and are stainless steel.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Where are the aero-modders? shizzler TDI Fuel Economy 130 November 18th, 2010 09:56
FS: 16" beetle hubcaps and 2 16in steelies with tires +15" passat hubcaps tdipower4me Private TDI Items for Sale/Wanted 2 May 20th, 2009 11:16
Aero exhaust mercinariesgtr TDI Power Enhancements 9 June 30th, 2008 05:56
Aero comparison ukemike TDI Fuel Economy 15 June 9th, 2008 18:27
Aero wipers diesel_lover TDI 101 14 March 28th, 2008 12:59
Page generated in 0.13960 seconds with 13 queries
[Output: 76.43 Kb. compressed to 67.18 Kb. by saving 9.25 Kb. (12.11%)]
