Old December 3rd, 2019, 07:24   #46
Mongler98
Scangauge II is seriously the best . Changed the way I drive. Also coolant temps vs bs VW temp range
Old December 3rd, 2019, 07:55   #47
I used a scangauge for a while, it was especially helpful on track days. But I took it out of my car, too much info. Not necessary for daily driving, IMO. I just plug in VCDS and check for codes periodically. Rocketchip shut off the check engine light in my car so I don't see what's up otherwise.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old December 3rd, 2019, 08:54   #48
1854sailor
Resident Curmudgeon
1854sailor's Avatar
I use the Scangauge in our GSW to monitor DPF temp so I don't interrupt regens. I'll be putting one in the new Golf too...
-George Bernard Shaw
Old December 3rd, 2019, 09:00   #49
I can tell when the GSW's in a regen without a tool. BMW, not so much.
Old December 3rd, 2019, 09:56   #50
Lightflyer1
Lightflyer1's Avatar
An OBDII dongle and an old android phone with Torque loaded on it is far cheaper and much better in my opinion than ScangaugeII. More info can be accessed and can also clear codes and such as well. The dongle is cheap (or can be) and so are old android phones. Not hard to setup either. I keep my old phone setup in the car just for this. I always have VCDS handy on my tablet if needed but not easy to drive around with it connected.
Old December 3rd, 2019, 10:20   #51
1854sailor
Resident Curmudgeon
1854sailor's Avatar
I guess my ears aren't as good as yours...
Old December 3rd, 2019, 13:55   #52
Idle speed bumps up about 50 RPM, that's the tip-off for me. If I think it's up I will listen for the fans before shutting the car down. But honestly I'm unwilling to let the car dictate when I stop and shut it down. It should be fine if I interrupt a regen now and then.
Old December 3rd, 2019, 16:14   #53
AndyBees
AndyBees's Avatar
Well, IndigoBlueWagon, you've gone and hurt my feelings ......."..too much info."..
Hmm .... well, besides Scan Gauge, below is what I monitor in my Vanagon with the ALH engine....
Top, L to R..
McNally EGT/Coolant Combo, VDO Boost/Vac, Oil Coolant Temp (temp of coolant coming out of the oil cooler)
Bottom, L to R...
Coolant System Pressure, Vacuum System Vac, Volts and Oil pressure
You can also see the Speedometer of the Jetta Cluster.
Not in view, is a small green LED light indicator that tells me when the AC Compressor is engage. Also, I have an in-line fuel pump (auxiliary, for priming) with an LED indicator light showing when it is on.
Almost forgot, and below the four-pod gauge gang I plan to install a three-pod with "before and after" combo turbo charge temp, ???? and ????? .. Obviously, not sure about those last two might be (I'll take suggestions.....)
GPS up above out of sight ....
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
AndyBees is offline   Reply With Quote
Old December 7th, 2019, 12:03   #54
jjblbi
Fuel Economy: 41ish mpg post fix
Scangauge II rules. I have it in the left corner of my dash to monitor water, EGT, DFP temps and boost. I typically idle until EGT temps are down below 370F before shutting down. Also useful for more accurate water temps and regen monitoring. Cheap insurance for a long term vehicle.
jjblbi is offline   Reply With Quote
Old December 7th, 2019, 16:25   #55
Lightflyer1
But it costs nearly as much as the $199 VCDS. If I were to spend that kind of money I would opt for VCDS instead. Torque and a BT dongle is pretty cheap at less than $20.
Old December 7th, 2019, 17:44   #56
Mongler98
Where are you getting your prices from? I'm sure you can (I did) pick up a used scangaueII for $50 on ebay. The difference is that the II has 4 read outside while the E has 2. Yea the II is 134 on amazon and about 120 on ebay but you cant complain about quality stuff for your car that saves you money fairly quickly.
ScanGaugeE Compact Multifunction Trip Computer with Customizable Real-Time Fuel Economy Digital Gauges https://www.amazon.com/dp/B004SK5I46/ref=cm_sw_r_cp_apa_i_yCe7Db15N81RK
80 bucks
And it's the new version of the scangauge.
Old December 7th, 2019, 19:24   #57
Lightflyer1
Well I was quoting new prices but VCDS can be had used as well. It is much more useful than the scan gauge as well. But the OP didn't want to spend any big money so I think that rules out most things we use and takes it down to the Torque and BT dongle. For $20 you can't beat the usefulness of it. Rent or find a local owner of VCDS when you actually need the tool.
Old December 7th, 2019, 20:11   #58
Mongler98
big money? some people have very low standards. To me Big money on a car is at least $1,000 for a part or something like this. $100 is still a big deal to me (heck im ticked off when i have to spend $5 on something) but i see value beyond the price for this. I jumped 5mpg better overall by having scangauge show me real time GPH and MPG. i have a lead foot apparently when normal driving.
OP just keep an eye out for deals, eBay bucks, discounts, fire sales, and so on on these parts.
every few blue moons eBay has a $20 off thing or 5% and so on. combine that with some strategic eBay purchases of things you normally buy to rack up more in ebay bucks, use befrugal to click though for a few extra % and you can really rack up a decent savings on an item that comes up used on an already good deal.
Old December 8th, 2019, 09:50   #59
Lightflyer1
Well your idea of expensive and the OP are different it seems. They expressed that even $200 was way too much. To me this means the cheapest you can get and still get the job done. Assuming you have an Android device that would be what I suggested. Hard to beat $20.
VAGCOM diagnostics help: 2009 VW Jetta 2.5 VWJettaMike TDI 101 8 November 30th, 2019 20:37
Suggestions for good resource on newer GTI's? '09 and newer? petee_c Ontario 20 November 7th, 2017 11:38
About had it with my VW. Is reliability of newer VW's better? Compared to Toyota? fishugly General VW Discussion 37 July 5th, 2014 17:28
VAG 409.1 OBD2 USB Auto Diagnostics Scanner + VCDS Software for VW Audi chemist_dude OBD Scanners 3 March 3rd, 2014 05:16
VW The First With Diagnostics? El Dobro General VW Discussion 8 April 1st, 2008 14:20
Page generated in 0.16899 seconds with 13 queries
[Output: 125.02 Kb. compressed to 104.92 Kb. by saving 20.10 Kb. (16.08%)]
