Old December 2nd, 2019, 14:56   #1
Westwindmk3
Default Glow plugs issue
Hello everybody,
My car is golf 3 1996 TDI.
The problem is that the glow plugs indicator isn't showing on the cluster, no voltage on the wires to the plugs either. I measured current between 87 and 30, it's ok 12.5v. I measured 86 power from ignition is also present, 85 is about 6volts coming from the ECU. Fuse is also OK.
I'm really confused at this point. Are there any other components that interfere in the preheating system apart from the coolant sensor? I haven't measured continuity of wires from the relay to the plugs. that's the last thing I could go further with my knowledge.
Any other suggestions will be really appreciated.
Thanks.
Westwindmk3 is offline   Reply With Quote
Old December 2nd, 2019, 18:35   #2
Mongler98
i just saw a thread recently where its just a matter of getting the multimeter on really fast, something about voltage dropping really quickly.
Old December 2nd, 2019, 18:41   #3
Vince Waldon
Vince Waldon's Avatar
Find the fantastic multi-page "Glow Plugs 101 V2" thread and read read read..... lots of great info, pictures, etc.
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Old December 5th, 2019, 00:30   #4
Westwindmk3
I tested all again, this time everything works as it is supposed to apart from the indicator light in the cluster. I'm sure that there is no problem in the cluster or the glow plugs bulb. Is the waiting period plug light controlled by the ecu or the relay?
Old December 5th, 2019, 20:04   #5
Mongler98
it is, via the MAP program in the ECU, it can be set with VCDS to longer or shorter. (i think) or it has to be done with a tune, If i remember correctly, its done with VCDS.
you sure the bulb is still good???? its nearly a 30 year old car!!!
Old Yesterday, 00:29   #6
garciapiano
if the glow plug lamp doesn't come on briefly in the dash upon first key-on, your bulb is out. If the bulb is out you will also get a code stored for glow plug indicator lamp open circuit.
One way to test if the glow plugs are actually cycling is to disconnect the coolant temp sensor harness plug from the sensor located on the outlet flange (NOT the A/C temp switch on the upper radiator hose). If the coolant sensor is not detected by the ECU it will cycle the glow plugs for the maximum duration, with the corresponding light on in the dash.
garciapiano is offline   Reply With Quote
Glow plugs/coolant temp sensor issue TripXAnarchy99 TDI 101 17 November 15th, 2017 05:20
Glow plugs don't work, new plugs, new harness, new relay, good fuses Matthewsz TDI 101 19 February 9th, 2016 07:42
coolant glow plug/plugs issue 1999.5stu VW MKIV-A4 TDIs (VE and PD) 22 January 11th, 2015 13:56
Intercooler Issue (Flashing Glow Plugs) cmeller VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 22 January 23rd, 2013 20:45
2 dead glow plugs, harness hot, relay issue Eco-Craft TDI 101 15 November 13th, 2009 11:31
Page generated in 0.13744 seconds with 13 queries
[Output: 73.91 Kb. compressed to 64.78 Kb. by saving 9.13 Kb. (12.36%)]
