Old October 11th, 2018, 06:44   #1
ovidiu.buzzi
TDI(s): 2.0 TDI
Default VW Golf 1.9 TDI no ignition lights on dash
Hello i have a VW Golf 1.9 TDI 105 HP end of 2006.The problem is that a friend of mine remove the dash to fix something and after puting all toghether no more ignition lights on the dash, windows not working.I did check relay and fuses everything is ok.What i did discover is that the 460 relay on the bottom left relay carrier doesn 't activate.I did remove the cap of the relay and activated manual and the dash lights switch on and immo ok.What i dodn t know how are the power lines that energise the relay and the current flow .Does anyone have any idea on what the log is sayin?Thank you
Vcds log is this:
Thursday,04,October,2018,16:41:21:59248
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.5
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: WVWZZZ1KZ7B057392 License Plate:
Mileage: 153030km-95088mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ7B057392 Mileage: 153030km-95088miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BH HW: 1K0 907 044 BH
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6ED311FC79707534C6-803A
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AL HW: 3C0 937 049 AL
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007509636
Coding: E5890F2700041500471400001400000000097F075C00010000 0000000000
Shop #: WSC 00179 572 88471
VCID: 73E50088125258DC29-8026
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 010906 020 0501
Coding: 00038805
Shop #: WSC 00179
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 160506 014 1201
Coding: 00208933
Shop #: WSC 00179
3 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01111100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 153039 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 153039 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
01049 - Supply Voltage Term 50
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 190
Mileage: 153039 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 11.75 V
OFF
ON
ON
OFF
OFF
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 873 B HW: 1K0 920 873 B
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F7102963
Coding: 0003103
Shop #: WSC 07059 843 03230
VCID: 2B55D8E88AE2401CA1-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 3100106826809B
Coding: 3D0F0B4007000000
Shop #: WSC 00046 412 688128
VCID: 2C57DBF48FEC4724A8-8078
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51D6F0B4F64E2CBF-8078
End-------------------------(Elapsed Time: 01:30)--------------------------
Address 19: DTCs clearedFriday,05,October,2018,13:36:35:59248
www.Ross-Tech.com
ovidiu.buzzi is offline   Reply With Quote
Old October 11th, 2018, 16:03   #2
Ol'Rattler
Ol'Rattler's Avatar
A VCDS scan and troubleshooting the 429 relay is pretty worthless for situations like this if everything worked prior to your friend working his "magic" on your car. Clearly something was not plugged back in, not plugged back in correctly or some wiring was damaged.
Your friend needs to figure out what he did wrong. One thing you could check is if your friend didn't disconnect the battery before he yanked the dash, he may have shorted something out and blown some fuses or fried some wiring.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Will VW dealer do emissions fix if my car has dash lights on? seyser VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 October 13th, 2017 19:45
Golf MK5 TDI GT non start, no crank, no dash lights sam_rip TDI 101 2 October 1st, 2015 09:33
Golf mk5 dash lights stuck on King of leons VW MKV-A5 Golf/Jettas 0 April 23rd, 2013 12:33
Page generated in 0.12946 seconds with 13 queries
[Output: 59.20 Kb. compressed to 55.18 Kb. by saving 4.02 Kb. (6.79%)]
