dvldog8793
Howdy
Car is a 2009 Jetta TDI with 80K miles. Has been in a deer induced crash in the front left corner, repaired and ran great.
I have had several electrical problems and it seems be cascading into more.
Some of these I have posted about but now it seems to be getting more involved so Ill start a new post.
Initial problem- Radio stopped working, blowing the 15 amp underhood fuse instantly.
Ran a scan- Only codes related to the radio were sat radio not responding(I don't have one) and radio was not talking to the computer. it also had a code for the rain sensor that I wasn't aware I even had. I stored and the cleared the codes, disconnected the Battery, replaced both the radio fuse and the rain sensor fuse. Hooked up the battery and all the codes came back AND the headlights came on. I attempted to read and clear again and the Rosstech VCDS lost "gateway" and have been unable to get back into the ECM.
Found that the fuse box AND 15amp radio fuse were melted. replaced fuse box and main "panel" fuse block.
So right now:
- car will turn over but not start
- Headlights come on with the key
- after initial glow cycle the glow light flashes
- under hood radio and interior rain sensor fuses blow instantly
- Unable to communicate with ECM via OBDII or VAG with Rosstech. OBDII connector never sees signal from the car.
What I've done:
- NEW proper battery
- NEW VW underhood fuse panel and fuse block
- inspected and cleaned all grounds that I can find.
- Tried all three keys that I have
- removed rain cowl, unhooked ECM and visually checked the harnesses and connections. Cleaned said connections.
- visually inspected the interior wiring.
- removed the remote start system that never worked and we never used.
- read, stored and cleared initial codes with rosstech VCDS.
- removed and visually inspected all fuses
With all the (seems to be) unrelated problems it sounds like a harness issue?
Is there a good way to trouble shoot a wiring harness in these cars?
ANY IDEAS and advice would be greatly appreciated.
Thank You !
So right now:
What I've done:
Thank You !
