meerschm
- Joined
- Apr 18, 2009
- Location
- Fairfax county VA
- TDI
- 2009 Jetta wagon DSG 08/08 205k buyback 1/8/18; replaced with 2017 Golf Wagon 4mo 1.8l CXBB
copied from post 12 on previous page.
the small plug can be removed, which will let oil in the filter area drain.
from the video, you can see there is a bunch of stuff under, which is likely to be covered in oil, unless somehow covered or pushed out of the way.
as mentioned earlier (or at least hinted at) similar designs on earlier VW gas engines had a valve under that small cap that enabled use of a screw-in tool with drain hose to operate the valve and drain oil, which reduced some of the mess.
then the larger cap has to be removed, then the filter, which comes out the bottom.
I guess the jiffy lube is ok, if you bring your own oil and filter, (or at least verify they have the right stuff) Better than draining the oil on the side of the road.
call it personal preference, and local options available. I used a quick oil place for a while when i first moved to DC area. no place to do the work.
Not really rocket science, but a lot of screws to loose track of in the bottom cover, and easy to over-torque filter cap and drain plug.
