Humpty
finally found a tdi and went through with it! 2002 jetta with just a tick over 200k. Timing belt replaced at 188 i have the receipt to prove it from a small vw shop. Now i have a few questions. I would like to inspect the intake and make sure it isnt clogged to hell, is there a way i could do this without pulling it off?
Also, i noticed there was some oil around the filler cap, im guessing this is just from not using a funnel or something when filling
Im also asking what i should do now to get the car in tip top shape. Im going to inspect the turbo and make sure the lines are good and all that, do the oil, check all fluids.. etc is there anything in particular i should look out for? Thanks!!
Here she is
[/url][/IMG]
Here she is
