Old August 18th, 2019, 13:51   #1
Garrison
TDI(s): 2006
Default New Ride - Cam Wear? (Pics)
Good Afternoon,
I'm looking for some feedback (all opinions welcome)
Picked up a 2006 Jetta Grey/Grey with 263,000 miles on it - a lot of miles to be sure, but the car was seemingly well cared for, and the father of the owner a diesel mechanic. After taking a look through everything and driving it I was sold.
I'm anticipating a few repairs ahead with so many miles; one I would like to avoid if possible is the cam shaft replacement. Can you please have a look and let me know your thoughts on their status from these pics?
Thank you!
Garrison is offline   Reply With Quote
Old August 19th, 2019, 12:53   #2
JETaah
If it is scuffed on the back side of the cam it is the beginning of the end.
If the lobes are crowning in the longitudinal direction then the lifters are dished.
Google 'BRM camshaft wear' and you will no doubt find volumes of info on what to look for.
More severe the crowning, the less time you have before the "thumping" sound in the intake starts.
Your pictures do not reveal the crowning as of yet but the scuffing is there so I would keep tabs on it more frequently if you don't want address this eventuality now.
At 263K it may well be a replacement cam that is in there.
Old August 20th, 2019, 05:28   #3
Garrison
TDI(s): 2006
Okay understood, thank you very much!
I have about 40k to go on the next timing belt change (300,000mi) - and I'm going to keep the fluids swapped and clean as I'm able; when Im looking to do the timing belt change it looks like Kerma sells a $1400 package with a hardened cam & timing belt supplies.
Would you recommend going that route, or is there another method of achieving longevity with this car that I'm missing?
Old August 20th, 2019, 07:25   #4
JETaah
Lot of people have had good longevity with both the Colt cam which I think Kerma is offering and the Franko6 cam both due to modifications to the cam profile. Frank has a kit that has modified cam journal bearings for better oiling and chromed cam journals. It is probably somewhere in the same vicinity price-wise. His includes two treatments of break-in oil and filters as well plus reusable hardware.
I will let him do the selling on this. Shoot him a PM for info.
At this point you have likely worn through the hardened surfaces of the components so thing will wear at an accelerated pace. Changing the oil too frequently will not do much and may defeat your good intentions. Just remember to use the proper oil in the future.
Old August 20th, 2019, 21:12   #5
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
I believe it is difficult to judge wear by photos. I suggest you carefully feel with your fingertips the edges of the high points on the lobes. If they have a sharp edge, it is new cam time.
sptsailing is offline   Reply With Quote
Old August 26th, 2019, 13:41   #6
mextdi
If in doubt, I would just go ahead and do a timing belt and camshaft replacement. It will go far into giving you peace of mind. If you can do the timing belt, it is not difficult to do. Just AVOID chinese made parts as they are prone to breaking shortly after install. A new camshaft and related parts are not extremely expensive.
mextdi is offline   Reply With Quote
Old September 5th, 2019, 16:43   #7
Franko6
sptsailing is a customer of ours, but I must disagree. The pictures tell the whole story. There is very obvious damage on the #6 and #8 cam lobe. The cam lobe, including the base circle should be smooth and shiny. This one is not. The roughness will tear up a cam follower very quickly. Before you do damage to the oil pump, you should get the job done
The most prevalent damage that is easily found is the small chamfer that is on the circumference of the cam lobes on both sides. If the chamfer is gone at the peak of the lobe, you have a minimum .015" wear, when .006" is substantial.
Let me know if you would like to work with us.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old September 6th, 2019, 15:04   #8
echofilter
Franko6 is far more qualified than just about any of us so you should listen to him about the cam wear, but I want to add in that your camshaft is definitely starting to look worn, and provide pics of mine that I've literally just removed in the last month for comparison.
This is what my camshaft looks like after being removed (the rust is from all the places that were scratched like yours. Surface hardening takes very little to wear through) and the wear on the lifters. Car has 255k on it and I was barely starting to hear a thudding from the IM without removing the airbox. Acceleration was still okay, but FE sucked at about 33 MPG.
Besides some minor hiccups from my dumbassery(I really highly suggest getting a set of reusable bolts for the cam. If you're uncertain of anything or mess anything up it is very easy to feel like you should remove the cam caps to double check, and if you've already done final tighten, now you have to wait for a new set, seriously don't reuse them I broke 2. It was horrible.) changing the cam is really not that bad.
Additionally, knowing 100% when the timing belt was done is worth just doing it while you're there (remove the tensioner stud, don't remove the motor mount)
https://imgur.com/a/rlsfAs7?fbclid=I...T48Hkx-wCNXGZ0
https://imgur.com/a/rlsfAs7?fbclid=I...Nc-aTLh4qcGUcM
https://imgur.com/a/FtSnvbS?fbclid=I...bE0ezYWJvfd1l4
https://imgur.com/a/yHdePye?fbclid=I...E3PsfdWP8tw8ZA
https://imgur.com/a/n10QkO1?fbclid=I...mtduEsltRVY1SM
https://imgur.com/a/8S1ezw6?fbclid=I...UoDeVcsyLFvCso
https://imgur.com/a/8jxX4zY?fbclid=I...tgcSQmZLXYlsLc
echofilter is offline   Reply With Quote
Old September 6th, 2019, 15:32   #9
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Cam shaft needs replacing, one of the pics shows a worn-non shiney surface to the right side..trying to determine how long it has left on it is key, but is dependent on oil type, driving style and conditions and OCI and additives..
I have a 200000m 2006 DE that I run eurospec 0W-30 but use additives and run a 20000m OCI.
My other is a 2005.5 130000m 20000m OCI, 5W40.
Both of the cams are OEM, both have minimum wear on them, both cars OEM oil filters and oiling systems. I figured this one out some 10 years ago..
2018 F150 3.5 ECO 3.55 10spd 20s 2tone 26mpg 2turb
2006.5 DE DSG, RC2, Sunroof, 200K miles, 61MPG best
2005.5 Jetta-5 SP LSD Spec S2 130K ELF506 10-30W OCI=20k ORIGINAL CAM RSB Diesel custom 2.5DP/3" SS Pkg 1 Auto-dim mirror auto-WW auto-climate 248tq=150HP RC2 lowered 312 brakes
Mach1 is offline   Reply With Quote
BHW Cam Wear... and replacement (pics) CharlieT VW B5 Passat TDIs 91 July 17th, 2011 16:22
odd cam wear and pics to compare nestea VW MKV-A5 Golf/Jettas 7 February 22nd, 2011 08:59
Cam Wear (another post with pics) airwolf VW MKV-A5 Golf/Jettas 20 November 16th, 2010 21:06
Just discovered I have PD CAM wear at 59K! Help! (PICS) CATDI VW MKV-A5 Golf/Jettas 31 July 20th, 2009 12:29
Early cam wear pattern pics 2footbraker VW MKV-A5 Golf/Jettas 16 June 17th, 2009 22:15
Page generated in 0.20269 seconds with 13 queries
[Output: 96.36 Kb. compressed to 83.25 Kb. by saving 13.11 Kb. (13.61%)]
