phantom1260
I was doing some work on the trailer wiring on the car and when I was done I noticed the car lights were stuck in the on setting. I also swapped the the interior dome lights and the trunk light to LEDs before I noticed the issue.
Are all on and stay on regardless of the headlight switch position. They do all go off when the car is off but remain on if the car is on.
On the trailer wiring all I did was cut the stop(Brake) wire from the powered curt controller to get my brake lights to work on the trailer. Which they do now.
My aftermarket back up camera wiring was also loose so I reconnected that to the back up light wire with a T-tap connector. I also wired a OBD II port connector to my kenwood headunit for the gauges leads.
I looked at the headlight fuse under the hood and it seemed fine. Its a 30 amp whereas the manual states it should be a 40 amp. Also when I removed the fuse only the driver side headlight went out every thing else remained on.
I removed the headlight switch and that made no difference as well. Since I was doing so many wiring repairs I'm not sure which spot of the car I might have messed something up. Or if it's just a coincidence and the problem is unrelated.
Anybody have any other ideas?
- Tail Lights
- Headlights
- Licence Plate Lights
- Interior Illumination Lights (lights behind all the controls)
