I'm coming up on 35k miles and I've been thinking about getting an extended warranty. Since VW does not offer extended warranties directly, what is a good 3rd party extended warranty to go with?
I do not want to go through my dealership since they make commission off of you.
TDI THIS,
VW offers a warranty called VW Drive Easy. They do not directly sell it, it is sold by their dealers.
I charge $300 over the cost.
It is written by VW, backed by VW, and has their insignia on the contract.
It is facilitated thru Fidelity Warranty Services.
Here is my thread and quotes on the Platinum plans
Newly revised as of Jan 3rd, 2014
Here are the numbers for the all new 2012, and 2013, and 2014 VW Passat TDI's
Chris here from Burlington VW in Burlington, NJ.
The VW Drive Easy extended service contracts have changed as of Jan 01,2008
They have now combined the new car extension w/ the used car extension and
have come up w/ one main plan.
Now the time starts the day you sign up and the miles you choose are on top
of what you allready have!
They still have the same verbage in the new contract as far as coverages
that will be explained here:
> Allthough I am open to all coverages, I would reccomend the Platinum
> coverage as it is an exclusionary warranty vs an inclusiuonary warranty!
> These quotes are w/ a std $100 deductible.
> Should you want a $0 deductible, please add an additional $230-$517
> depending on the terms you choose!
The $100 std deductible is per visit, NOT per complaint!
> This extended service contract is valid at ANY VW dealer and the dealer
> gets
> paid thru their parts and warranty dept.
> This warranty is also valid at authorized shops and they get paid thru a
> credit card.
> You are never responsible for more then your deductible!
> If you cancel in the first 60 days, it is 100% refundable, after the 60
> days, it costs $50 and the plan will be pro-rated!
> To transfer the contract it costs $40!
> The warranties I sell are geuine VW warranties. I DO NOT deal in
> aftermarket
> warranty companies! The service contract is backed by VW and fascilitated
> thru Fidelity Warranty Services!
> Here are the coverages:
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> The Gold Plus covers all of Gold plus:
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> The Platinum covers all that and the rest of the entire car w/ the
> exception
> of this:
> brake linings,brake drums and rotors,disc brake pads,std trans clutch
> components,air bags,solar powered devices,hinges, glass, lenses,sealed
> beams,trim moldings,door handles, lock cylinders,tires, batteries, light
> bulbs,upholstery, paint,bright metal,freeze plugs,heater and radiator
> hoses,exhaust systems,shock absorbers,audio,security or other systems not
> factory installed, work such as front end alignment or wheel balancing,
> constant velocity joint boots, safety restraint systems,cellular
> phones,electronis transmitting devices{except those specifically listed
> under silver, gold, or gold plus coverage},radar detectors,appliances,near
> object avoidance systemand all oither laser radar cruise control
> components,
> vinyl and convertible tops.
Here are the quotes depending on how many miles are on your Passat TDI
Please note that this contract starts from the day you sign up and the
miles
are on top of what you allready havexxxx +
These quotes are vaild until you hit 9999 miles or the end of the year!
4yrs or 100K=$1634
5yrs or 75K=$1311
5yrs or 100K=$1731
6yrs or 60K=$1182
6yrs or 72K=$1401
6yrs or 85K=$1509
6yrs or 100K=$1902
7yrs or 70K=$1484
7yrs or 100K=$1969
If you want the 4yrs or 100K Powertrain Only
$980
Valid up to 24999 miles
This would carry you to 124999 miles total
4yrs or 48K=$1434
4yrs or 60K=$1702
4yrs or 100K=$2068
5yrs or 60K=$1791
5yrs or 75K=$2030
5yrs or 100K=$2355
6yrs or 60K=$1860
6yrs or 72K=$1964
6yrs or 85K=$2418
6yrs or 100K=$3124
7yrs or 100K=$3406+
Up to 34999 miles
3yrs or 36k =$1564
4yrs or 48k =$1915
4yrs or 60k =$2127
5yrs or 60k =$2187
5yrs or 75k =$2555
6yrs or 60k =$2310
6yrs or 72k =$2572
Chris
Chris
Chris Farnham
609-850-0244
